Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn Air JCD2389GTW Refrigerator problem
My freezer size of this appliance seems to work fine but the refrigerator side is warm. I suspect that the auto defrost system may be the culprit. Any ideas?
Both the main fan in the compressor compartment, and the small fan in the freezer compartment are working. Yes, the coil and everything else was frozen up, so a defrost problem may be the cause. However, removing all the ice didn't even temporarily improve the 'fridge temperature, which will not decrease below 50F, whereas the freezer will happily reach the correct temperature. There seems to be air flow through the small panel which moderates the door cooler, and some through the larger opening at the second drawer.T here was no obvious ice in the two ports adjacent the interior fan, though i didn't probe all the way down these two openings...can I? or are there breakable restrictions /valves in there?
model jcd2389GES, serial # 14063794AJ, which must code the manufacture year. Any help appreciated
  • 8 more comments
  • kauaiboy3 Jan 26, 2008
    I have a Jenn Air JCD2389GES it freezes up in vent and frig get warm. Is it the fans? Any help?
  • Anonymous Jan 29, 2008
    Looks like an epidemic! my Jenn Air JCD2389GES also is freezing in the freezer, yet only about 50 degrees in the fridge side - what's up here???
  • fintoo Feb 27, 2008
    Not cool at all!!! I mean this epidemic and my refrigerator, not cool. I really think it's programmed in the microchip to fail in Jan.2008. Mine has done the same thing. Not sure of my model # but definately the same problem. I'm hopefully getting the board local and replacing it tonight,
  • Purana Feb 28, 2008
    I agree mine has done the same thing.... Not cool at all!!! I mean this epidemic and my refrigerator, not cool. I really think it's programmed in the microchip to fail in Jan.2008.
  • Carla Carpenter Jun 10, 2008
    My problem is the same. The frig is warm and the freezer is fine. Had a repair man out, and he replaced the circuit board that controls the defrost. And defrosted the freezer coils. But, frig still didn't get up to proper temp. A week after the repair, the frig is now warm again. Repair guy returning today. We'll see what he says. This frig is 6 years old.
    Generally NOT happy with this product, especially for what we paid for it.
  • VPPR Jun 13, 2008
    I have exactly the same issue. Unit purchased in January of 2002.  We have used the defrost and hair dryer method  8 times, each time discarding a refrigerator full of warm food..  The last time was 3 weeks ago and we have the same problem today.  We will never purchase a Maytag
    Jenn-air product again.  I am thinking of leaving the freezer back panel off with the coils exposed so that at least it will be more obvious that we need to defrost, in the remaining months that we have with this refrigerator.  I will also try to use the info in an earlier post to locate and test the defrost timer.  I will report back after I complete the 3 hour task of removing fridge freezer contents to cooler to remove back panel and defrost coils.
  • fbyrd99 Jul 01, 2008
    Same problem, but fixed it.
    The Jenn-Air refrigerator has all cooling units in the rear of freezer compartment. A fan blows air from the freezer rear over to the top of the refrig side (thru styrofoam ducts). Over time (when older) you will need to thoroughly defrost the freezer rear coils and clear anything (ice) that is blocking cold air-flow thru the styrofoam ducts going to the refrig. Here is what you do...
    1. Defrost the freezer: Remove all items from the freezer side (food, shelves, ice maker). Remove all rear panels covering the cooling coils and fan. Remove all ice and frost buildup.
    2. Check the styrofoam ducts for obstructions. In the refrig side check the cold air control regulator plate/mechanism, located in the top rear (remove the white plastic top cover/ceiling). I completely removed the small white air control plate & spring that was blocking the cold air flow, and chose to not reinstall it.
    The refrig now works as good as new. Note that the crisper and milk air can be cold, even if the refrig side is not. This is because the crisper and milk get cold air from the freezer air, and not from the freezer rear coils.
  • georgiabelle Jul 12, 2008
    Had the same problem. Just defrost the freezer and the air wil flow better to the refrigerator. You can just take out the frozen food, put it in a cooler, and leave the door open until the ice melts. Or you can use a hair dryer on the coils and fan area until all of the ice melts. That's all it took for me.
  • Anonymous Oct 14, 2008
    We have the same problem. This is the 4th time we've had to defrost the coils with a hair dryer. We've had this fridge since 2002 and just this year (2008) did this **** start. From the other posts, it sounds like a repair man isn't going to do much so why waist the money? I may just go out and get a new fridge today. :-(
  • jle524 Oct 21, 2008
    we have the JCD2389GES. it is the biggest piece of **** that has ever been made. after reading all of the complaints on the Jenn Air appliances, it is apparent that the company keeps making a product that is not made to last over 4 years and that doesn't keep food frozen or cold. we have had the problem with the freezer ducts clogging and freezing up and also with the fridge side not keeping food cold. right now we are having the problem with the fridge side....again. its been a 3 year ongoing problem. we ave fixed it ourself numerous times, had a repair man come out and spend an easy $250 to fix nothing. and now we will most likely lose all of the food in our fridge this time.so, i have no solution to fix this problem anymore, instead i urge the person who is thinking about buying a Jenn Air to NOT BUY THIS PRODUCT...OR ANYTHING FROM THE MANUFACTURER!! you might as well just throw your $$ away in the trash!!!!!!
  • 10 Answers
Posted on Jul 01, 2008
    Sniper:
  • 65 Answers
Change the adaptive defrost board located in the upper right corner of refrig under the panel. remove panel by pulling on panel towards you from the finger holes in the rear. remove two 1/4 inch screws and two phillips screws. defrost manually with hair dryer behind panel in freezer.
Posted on Feb 18, 2008
We had the same problem with our same fridge. It's the circuit board for the defrost. Get that replaced and it works wonderfully!
Posted on Aug 03, 2010
Same fridge, same problems. IT WAS RECALLED so call Amana/JennAire and they will replace some parts.
Posted on Jun 13, 2009
I had this same problem, when I took the freezer apart I noticed there is a defrost heat elment at the bottom of the cooling coils. I tested the heat element it was good. With a little more research found there is a adaptive defrost module that controls the heat element. SO I picked up a new one at jenn air sales and service and changed it out. If you arn't handy you might want to call a repair man as this module is in the top of the fridge side above the controls. hope this helps jf
Defrosting the freezer is the key. Lots of ice buildup in ours. Thanks everyone!
Posted on Jul 12, 2008
Pulled the Freezer lower back panels off, and the coils were totally frozen up/closed...used a hairdryer [hung it inside, and shut door for 20 minutes] and it was defrosted. Be careful not to have the hair dryer too low where water will drip into it, and also be careful to not aim the hair dryer at the interior plastic. The styrofoam pass thru from freezer to the refrig side was fine, and not plugged. Turned frig back on, and it works GREAT. Mine JennAir was a "JCB2388GR"
Posted on Jul 05, 2008
Where's is the defrost drain for Jcd2389gt
Click Here=> Maytag JCD2389GTW Freezer Compartment is where you see the drain begin inside freezer and behind panel labeled location 20. The other end of defrost dran comes out below refrigerator and near condenser fan motor. How to clean a defrost drain Click HERE=> How to Fix Fridge Water Leak, Thanks Sea Breeze
Much more on this page=> Leaking Refrigerators!
May 05, 2012 | Jenn-Air JCD2389G Side by Side...
Freezer is running at a warm temp- cannot maintain a constant temp of -1. Refrigerator is fine and working properly. Anything I can do before calling a repair mn?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 15, 2011 | Jenn-Air JS48SEFXDA Stainless Steel Side...
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-air fridge not working
If the back panel of the freezer is Iced up you may have a defrost problem. or the damper between the freezer and thr refrigerator is closed.
May 19, 2008 | Jenn-Air JFC2087HRP Side by Side...
Check the back wall of the freezer section for frost. If it is frosted you do have a defrost problem. Timer or heater related. More economical to repair than to buy a new system.
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
The auto defrost timer was broken, so my refrigerator repairman replaced it. The part is about $60. The bigger expense was the labor getting to the timer, which is in the upper right hand corner of the refrigerator within the plastic casing that houses the temperature control levers. He then had to remove the panels of the freezer and defrost the coils with a blow heater. It took several hours.
Feb 28, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn air JCD2290HES Refrigerator not cooling
Try defrosting ther could be an ice buildup in the channel between the fridge and freezer.
Feb 22, 2008 | Jenn-Air JCD2290HES Side by Side...
Guys first make sure the freezer fan is working, then remove the lower rear panel in the freezer and inspect the coil for excessive frost, if there is than use a hair dryer to thaw coil completely. If you guys then post your full model #'s i can help with figuring out why the defrost cycle isnt working.
Jan 10, 2008 | Jenn-Air JCD2290HES Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
2,271 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
