Question about Motorola Mobility H500 Wireless Headset
I have a i580nextel igot a h500
I charged then linked it then it asked for passcode hung the phone up then it would not go back to password ask it just would not find any device how can i link it up or reset to start hole prosses again.
Try turning the phone off, taking out the battery, put the battery back in and when you power up the phone, you should be able to start the paring process over agian. This worked on my LG Rumor. Hope it helps.
Posted on Jan 22, 2008
Please help
Go to the Motorola web site and find the user manual for the H500. The instructions are there. The passcode is probably 0000.
Go to the LG manual for Bluetooth to find out how to get the phone to search for the new device when adding a device. The steps are probably something like this:
1. Turn on the earpiece and the phone.
2. In the phone menu, go to Setup or Options, then Bluetooth, then Add Device.
3. Choose Search for a Device
4. The phone will find your earpiece, so select it
5. The phone will ask for the passcode, so enter it (again, probably 0000 but check the H500 manual)
6. Wait several seconds for them to synch.
7. You are ready to go
Sep 01, 2009 | Motorola Mobility H500 Headset
Bluetooth h700 setup
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to thephone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized. After this, it will ask for a passcode.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Aug 20, 2009 | Motorola Mobility Bluetooth Car Charger...
I forgot how to sync my motorola h500 to a new phone
you hold down the button untl the blue light stays on steady and then make your phone search for available bluetooths in range, and then when it asks for a code enter four zeros "0000"
from-KERFEW=LOS ANGELES
Mar 12, 2009 | Motorola Mobility H500 Wireless Headset
Mmc card unlock password
unlock yur mmcard on memory card unlocker a hardware used to unlock mmcard with 9vt battery
Mar 28, 2008 | Nokia N70 Cellular Phone
How do i connect H500 to my phone
Hey guys. found it. Go to
www.simoncells.com
then go to manuals
than click on the H500 Bluetooth.
It will walk you through step by step its pretty easy..
Or, you can do it easier.
- Press and hold the Power/Call buttom for 6-10 seconds, until there is a steady blue light
- when there is a steady blue light, go to your phone's Menu, then click on Bluetooth, than Handsfree, It will then start locating your bluetooth. In about 3-5 seconds it will pop up as H500.
-Connect to H500, or push Yes to Connect. (which ever way your phone tells you)
-It will then ask for a password. ALL PASSWORDS ARE THE SAME;AND CANNOT BE CHANGED.
- YOUR PASSWORD IS 0000. typle that in.
Congratulations! Your Now Connected.!
Good luck guys.
Any questions, im on here usually every other day
Ed
Feb 18, 2008 | Motorola Mobility H500 Wireless Headset
Pin for Motorola H500
The pin for most bluetooth headsets is: 0000
Jan 20, 2008 | Motorola Mobility H500 Wireless Headset
H500 bluetooth
AFTER CHARGING headset hold down big button in center of headset until BLUE INDICATOR LIGHT REMAINS SOLID BLUE
tHEN TURN THE BLUETOOTH OPTION ON YOU CELL ON
GO IN TO MENU UNDER BLUETOOTH OR CONNECTIONS SELECT ADD DEVICE YOUR CELL WILL SARCH FOR DEVICE WHEN IT FINDS IT THE NAME OF THE BLUETOOTH WILL APPEAR ON DISPLAY CELL WILL THIS ASK CONNECT OR BOND WITH DEVICE SELECT YES IT CELL WILL ASK FOR PASSCODE PUT IN 0000 THEN AFTER THIS BLUETOOTH HEADSET SHOULD START FLASHING INDICATING HEASET HAS CONNECTED
Dec 31, 2007 | Motorola Mobility H500 Headset
I have a problem with my bluetooth H500
You need to full charge both units first before to try them again. YOU MUST KNOW ONE MAIN KEY HERE IS THE BLUETOOTH HEADSET MUST BE IN PAIRING MODE WHICH IS MEAN THAT THE LED MUST IN STANDING MODE NOT IN FLASHING MODE AND WHEN THE LED OF THE BLUETOOTH HEADSET IS IN STANDING MODE, BRING IT CLOSER TO YOUR PHONE AND BE SURE YOUR PHONE BLUETOOTH FEATURE IS ON AND BE RECOGNIZED FROM OTHER DEVICES. Try to restart carefully step by step each device as described above and then if you still can not get them pairing then either on eof them has Bluetooth function impaired. You need to have another Bluetooth Headset to test whether your phone Bluetooth function or the Headset has it. Good Luck
Mar 30, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
26 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
