Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
No hot water or steam
No hot water or steam is dispensed, mashine makes a funny noise and than red light comes on. Buttons are not working, coffee doen's dispense. Cleaning the opening of the steam tube didn't help.
Please advise!
  • Anonymous Mar 30, 2014
    water not coming out of wand, its making noise but no water or steam comes out
    Scholar:
  • 67 Answers
Well, I have little exposure to Saeco, but a lot to commercial coffee machines.
Saeco have a lot of custom made components, although these can be purchased, nothing is cheap! Neither is their repair service!
First, is the boiler heating?? If so:
No hot water/ no steam suggests a blockage. Assuming you can hear the pump working when attempting to do a coffee, you will probably find the water flowing back into the water tank via the relief valve. Of course, this valve itself could be the problem, or the pump failing to work through a blocked inlet filter or other problem.
Look now at the group head. Ever cleaned it? The filter and spray block should be removable, do so and clean them carefully. While you have them out, see whether water reaches the head by "making a coffee" into a cup placed under the head. BE CAREFUL OF SCALDING. If water now flows, cleaning the screen and spray block should restore operation.
Beyond that, it's inside the machine! There is a 3- way valve that operates when making a coffee. This can become clogged with coffee. There is another valve to open the steam.
If, like Saecos I have worked on, the boiler does both the hot water and the steam one at a time, look for problems BEFORE the boiler.
Hoe this helps a little....
Posted on Jan 19, 2008
My caffitaly S 23 does not dispense hot Millikan after the coffee has dispensed. Just hot steam and a little bubbly hot water. I have cleaned it it and will dispense milk and the next cup doesn't.
First; I am NOT a Caffitaly repairman. Though I have worked on mini espresso machines. Sputtering and/or poor steam is an indication that your brewer is not up to brewing temperature.
** Most of these home machines have a very small boiler or tank. They are designed to produce hot water and sometimes steam to brew a small 'European' espresso. Here in the USA we like our coffee weaker and with lots of 'other' things mixed in. The 'Americano' is the same amount of coffee but with a lot of hot water added. This amount will tax the small boiler to it's limits. Top it off with a grande latte would be probably be beyond it's ability to completely froth/heat this amount of milk. When you order a Latte from a Barista you will note that it takes a while to froth a Pitcher of cold milk. They are using a large espresso machine and probably pulling a double shot of espresso. To make a similar drink with any home machine requires doing everything 'double' or twice brew. (3 times?) You will need to check the 'ready' light to make sure the brewer is up to heat prior to brewing your next cup.
** Suggest brewing a regular size or 1/2 a mug of coffee-latte then come back again later for another fresh hot cup.
Aloha! ukeboy57
Dec 21, 2017 | Coffee Makers & Espresso Machines
No water/steam coming out of wand
hi there,
do you hear the pump running when you ask for water or steam? You should hear the pump continuously when you ask for hot water, and intermittently when the steam is dispensed.
No hot water or no steam could come from many causes:
valve not working or not actuated (control board), and also the switch that closes when the water knob is turned may be defective.
Do you hear that switch clicking when you open the water knob?
Difficult to help further with so little behaviour information.
Good luck,
M.
Oct 28, 2017 | Saeco Vienna Plus Espresso Machine
Red light on no steam
Hey Michelle! Sorry to hear you're experiencing no steam.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=18994&cid=ccsocial
Mar 02, 2013 | Bissell 1867-7 Steam Mop Chemical free...
When you press the coffee button the machine grinds the beans, but then the water comes out the steam wand... please help
The problem is a very frequent one a small scale part have been moved and it stack to the water steam valve and it blocking it from closing completely. So when you make coffee the hose of water for coffee is in parallel with hot water steam wand and since the valve remains partially opened the water for coffee find easy escape from steam wand.
So we suggest to perform one more descale and it may need twice hopefully this small scale part to be dissolve a little bit more in order to pass thought the steam valve and thus the valve can close again completely. If you are not so lucky the part remain on the valve then only solution is to disassemble the machine thus clean the steam valve manually. In this solution you may find out that the valve o ring might be damage and thus the leak.
here is the link with steam valve parts and this the parts diagram of the machine and here many more for your machine
Aug 15, 2011 | Saeco Magic Comfort Plus Espresso Machine
Our machine will not make coffee or water will not come out of the hot water dispenser.
water and steam wand work
but i cannot get any response when i press the cup buttons
Feb 08, 2011 | Lavazza Espresso Point Capsule Machine
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
flash.
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
used.
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
No steam pressure with little to no water/steam
Remove the steam wand and inside you will find a small teflon like tube at the top, throw that away and run water through the wand to make sure it is clear then re-assemble in machine and test.
Jul 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
'Chugging' noise when trying to get flow of water from steam tube
You must press the hot water/steam button to make sure it is set on hot water. The chugging noise is the pump slowly putting water through the steam boiler for steaming. When you open the steam knob make sure it is all the way open, you will hear the microswitch click when you reach full open(test it out with the machine off). Red light also means heating and low on water, since you are using all the steam faster than it can make it hence the red light.
Jun 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
436 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
