Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Ink I change already the ink cartridge and keep saying NO cartridge.reinstall ink cartridge..what does this mean?
  • 1 more comment
  • turkey mama Feb 20, 2008
    My printer is not excepting the black ink cartridge I have turned it on and off several times with no availe now what
  • help11 Feb 24, 2008
    I change black ink cartridge and the LCD saying no cartridge. it also says that install cyan and open cover and install black cartridge over and over. please tell me how to fix the problem?
  • Anonymous Mar 17, 2014
    I replace my ink cartridges and it keeps saying it cant detect the ink. what can I do?
  • 832 Answers
Did you lock and secure the latches?
If yes and still this message, do you run generic ink carts?
If yes, the cart holder is stained with ink and the led-controll-board has a short circuit, which cant be fixed!
You need a new cart holder as a spare part!
Posted on Jan 19, 2008
Iv changed my ink cartridge and now it wont print it keeps saying ink cartridge has been changed
I just got mine working again. Solution: You have to disassemble your Printer. Take a close look at the small round motor inside. Their is a small toothed wheel attached to the shaft of the motor - mine was already lying inside the printer. This wheel hast to be replaced by a tighter fitting one or the original one has to be fixed to the shaft - I used glue, as i had no new wheel.
May 10, 2012 | Canon SELPHY ES2 Printer
Alarm message says "cartridge jammed". Does that
What you see moving is the print carriage. The carriage moves the cartridge, adjacent to the printhead, back and forth.
Although the carriage is moving, the ink cartridge can not dispense ink because an obstruction is
blocking the path of the ink.
Remove the ink cartridges, inspect the cartridges as well as the cartridge holders for any foreign debris and reinstall.
If the alarm message continues, I suggest changing the ink cartridges.
Feb 17, 2011 | Canon MultiPASS F50 All-In-One InkJet...
Message no cartridge when installing new cartridge. I have installed new ink cartridges but the printer keeps coming up with the message 'No Cartridge' Reinstall the cartridge. I have done this three or...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Thank you,
Mar 28, 2010 | Office Equipment & Supplies
My printer is ip1800
Keep your printer of nozzle checking. Refill Cartridge are most likely showing message "low ink", but it's actually not, i mean running good as new.
Oct 04, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Expired ink cartridge
You may be getting this error message due to the printer being able to tell that it is a non-hp cartridge. I don't know how it can tell, but mine says that too. I uninstalled the software and then reinstalled the software. And then I took out the cartridge and put it back in. See if this works for you.
Apr 07, 2008 | HP OfficeJet d145 InkJet Printer
Chances are the new cartridge is defective.
Check the expiration date on the cartridge, and even if it is not expired, I would suspect the cartrigde is bad, dried out, not allowing the ink to lower.
That is the most frequent issue with your problem
Feb 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
Changed blk ink cartridge and it says NO CARTRIDGE
see/search brother faQ:
Nov 09, 2007 | Brother Multi-Function Center MFC-3360c...
Re install ink
I know this is a dumb question but did you remove the tape off he bottom of the ink cartridge? Also sometimes if you are using a generic ink cartridge the machine may not recognize it. Make sure the cartridge is seated in properly and that it is in the correct location. (not color spot). Hope this helps. John
Sep 07, 2007 | Brother IntelliFAX 1940CN Plain Paper...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
196 people viewed this question
James Cagle
James Cagle
Jim Keysor
