No power going to the amp but power running everything else i have a soundstream amp and a power cap, there is power running to the cap and the neons but not to the amp i have check all the fuses and they are all fine and it was work right up till about half an hour ago, the power light on the amp is not even coming on normally the light will come on red if there is a problem but this time there is no light coming on at all
The capacitor will do little to solve the light dimming issue. You are experiencing the problem because you are at or near the capacity of the alternator/battery power output when playing your system at high volumes. You can add the cap in if you want to, the voltage specification is a maximum voltage, so it should not be a problem. I still doubt that you will solve your light dimming problem with it though.
well. if it doesn't function after smoking, then it needs to go to a GOOD technician. ( if one is available to you) if not then send it to soundstream. if this was not a good amp , I would advise getting rid of an amp that smoked, however soundstream is a good brand and deserves another chance. (always depending on the cost of repairs)
hope this helps.
if car shuts off when hot outside, change thermostat and radiator pressure cap.-- heres more-car shuts off when tempurature of engine gets to normal. causes; low coolant, failing coolant temp. sensor, air in water pump. it takes 10-15 minutes to reach normal range. hope this helps! good-day!
the Q4000 only funs 400 max and thats at 4ohms bridged 2x200 if you need high powered amps i would look at soundstream or MTX and you would need atleast 1 secondary battery cause to max a amp out you need to have constant 14.4 volts going to power the amp.
What are you running in to your amp? If it's a CD player or radio, find the wires from them, disconnect them from the amp and connect them to the equalizer, then connect the equalizer to the amp.
The amount of power that youre going to run on those 5.25s might indicate that you need to turn the crossover to a higher cutoff frequency because they gonna want to kick pretty hard if your set too low - Sounds like you got it under control though flip it to high-pass(HP) and see how it does at around 100 HZ cutoff- be sure to turn off any bass boost on the amp though too- Let me know how them soundstream mids do- I have a set of subs that kick *** but i never have heard anything about their mids-good luck
That depends on which wires you are referring to. High level inputs or low level (RCA) outputs? If you are thinking about trying to wire the amp up to your Pioneer direct, ie; running the power and ground off of the factory harness, think again, you'll fry your electrical system. You need to run a seperate power kit (8 gauge minimum; 4 gauge pref), then run RCA's from the line level outputs on the Pioneer. If you are planning to run a sub with the Soundstream then run your RCA's from the Pioneer's sub output. Let me know if I can help you any further.
Go by the fuse rating on the amplifier as a default. i.e. - If on amp has a 40 amp fuse on the outside and another has a 30 amp fuse on the outside, then you need to supply at least 70 amps of current. the formula works like this: amps X volts = watts. Doing the math here, for an amp to produce 1000w of power @ your vehicle's 12v power, you need 83 amps of current. Most cars produce 14v from the alternator when running, so this is really only needing 71 amps. Make sure your car's alternator can supply the excess current when running. Most modern amplifiers are efficient enough to produce their wattage with even less current than that.
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
