Question about KitchenAid KHHS179L Convection/Microwave Oven
Error Code What does error code F7 on this microwave refer to?
  • 2,337 Answers
F7 problems are usually caused by poor connections. I suggest to unplug the ribbon connector off the control board and cleaned the copper connectors using alcohol or with a pencil eraser. If that does not work the touch pad may be defective.
Posted on Jan 19, 2008
6ya staff
SOURCE:
I have a Kenmore Elite Speedcook Microwave oven, model #665.63783600. What does error code F7 mean on this model?
F7 Error Code On Microwave Ovens With Inverter Board
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
For more free help, feel free to contact me via my site with your detailed symptoms and full model number and FCC ID number as shown on the tag in or on the oven.
Nov 18, 2016 | Kenmore Microwave Ovens
Code f 7
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components. It should cover an F7 error code.
A video is available here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This may help:
MODELS: GH9177XL, GH9185XL, MH9180XL, MH7155XMS, & KHHS178L for example
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 15, 2013 | Whirlpool Microwave Ovens
F7 error code displayed
Hi jruszas,
This F7 error code that you have on your display is all about the function key stuck on ERC. The only way to resolve this is to replace control board (also called ERC or clock). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
May 22, 2011 | Whirlpool MH9181XM 1100 Watts Microwave...
Kitchenaid microwave runs for a few seconds and then shows error code F7. Kitchenaid Phone Center never heard of this error.
Hi alykat737,
This error code F7 on KitchenAid microwave is about a function key that is stuck on ERC. You will have to Replace control board (also called ERC or clock) to fix the problem. In case you will have to buy a replacement part you may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Feb 06, 2011 | KitchenAid KHMS2050S 1200 Watts Microwave...
Error code F7
Hi drk2676,
This error code F7 means that you have a function key stuck on ERC. You can solve this issue by replacing control board (also called ERC or clock). You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Feb 01, 2011 | Whirlpool GH6177XPS Microwave Oven
My kenmore elite microwave when turned on shows a f7 error code.
f7 keeps showing up and the microwave keeps cutting off,f7 code shows up. what do i do
Oct 26, 2010 | Kenmore 68361 Microwave Oven
F7 ERROR CODE ON GH6177XPS
This is a known problem with this unit, and whirlpool has put out a Service Flash out on this. The reason this is happening is Electrical circuit interruption between the L1 and Neutral in the microwave invert circuit. This has to be addressed by a Tech.
DrakeTech
Dec 24, 2009 | Whirlpool GH6177XPS Microwave Oven
Error F7
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Nov 18, 2009 | Whirlpool GH9176XMS 1100 Watts Microwave...
F7 Error code
Please reply back with your model number so we can help you.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
May 30, 2008 | Microwave Ovens
KitchenAid KHHS179L Convection/Microwave Oven Logo
833 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
