Question about Alpine CDE-7856 CD Player
Cd won't eject
I have had this cd player for a couple of months everything is connect right, i know because in my spare time i work on car stereos, but anyways starting about a week ago every time i hit the eject button to take the same cd that has been in there since it started happening, the play won't eject, it doesn't make any sound and seems to freeze on the eject screen for about 30 seconds and then just goes back to whatever i was on before i hit the button.
is there any way to fix this or am i going to have to get a new stereo?
  • Anonymous Jul 12, 2008
    I dont know if my alpine system is the same but i got in my car, changed the cd and then a couple of minutes later i went to change it again and it wouldnt eject nor would it tilt......what can i do?
    New Friend:
  • 105 Answers
Sounds like the c.d. has a paper label on it, yes? my stereo won't eject c.d.'s with paper labels,....reach in there with a pair of thin needle nose plyers and yank it out,.....good luck, cracklin joe,......
Posted on Jan 08, 2010
6ya staff
SOURCE:
I have 2003 toyota camrey and im having trouble with my cd player/ radio. I pressed the eject button my cd came out and i tried to put another cd in and it wont go in. so then i pressed the eject button...
get a new cd player... u could have already purchsed one instead of logging in to post this... plus aftermarket are better then stock toyota stereos anyway
Feb 23, 2011 | 2003 Toyota Celica
I have a cd stuck in my car stereo and i tried pulling the fuse, that did not work, it does not even read that there is a disc in the stereo, i cannot find the pin hole to use the paperclip with? do i have...
Had a CD stuck in my Lexus for a year. Got my battery replaced and voila - the next time I turned on the CD player, the long lost stuck CD popped right out!! Must have been one of those reset features where you ahve to totally disconnect power from a component to alloww it to reset. Worth a try anyway.
Apr 12, 2010 | 2006 Hyundai Elantra
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
This problems has happened two times in the last 2 months. When I put a CD in the player it plays fine. I stop somewhere, turn the car off, with the CD still in the player and when I restart the car the...
There was probably a bad connection to the power supply. There are three wires. RED is battery(12 volts at all times)YELLOW or ORANGE is acc.(12 volts when key is in acc position) BLACK is ground(connected to any metal part of the car). Pull out the stereo and make redo these connection and makes sure they are right this time.
Aug 11, 2009 | JVC KD-G230 CD Player
The radio/cd player on my 01 yukon loses the sound randomly. Some times it works fine then othertimes it does it a lot. This all started a month ago. Before then I'd had no problems. I talked to a guy at a...
sounds like the amp is over heating and needs to be replaced
and yes there is most likely an amp in the system and it is eithor over powered or over heating
Jul 29, 2009 | Car Audio & Video
Looking for this part from Panasonic CD or DVD player: PPN13KA12C
Is your Lexus 2/3 generation Navigation system not working? Famous 'No disk detected' message?
I was lucky a month ago and got a used one motor. Repaired my DVD and the GPS works fine. Then I wanted to buy couple more motors in case my wife's Navi goes bad and to have some spare ones. I bet I was searching under both PPN13KA12C and PPN-13KA12C (proper designation) for over a month every day, couple of times a day, and nothing, until today. Google PPN-13KA12C and go to SMC Electronics - CD and DVD Repair Parts to buy them for $6.50 plus shipping. Hurry, they won't last.
Apr 03, 2009 | 2002 Lexus RX 300
What wires do i connect for my cd player? What colors connect?
here are the factory wire colors and what they do.
1999 Ford Escort
Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Green
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: White/Orange
Car Stereo Amplifier Location: Under the driver seat.
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
Mar 04, 2009 | 1999 Ford Escort
Cd keeps ejecting
use a product called cd kleen it.you can find them on ebay.they take care of problems like this.
Sep 06, 2008 | JVC Arsenal KD-S6250 CD Player
Car stereo shuts off
IS IT A GOOD QUALITY CD OR A HOMEMADE ONE ? SOMETIMES THE HOME MADE DISC DO NOT GET FINALIZED AND THEN THEY WILL ONLY WORK ON THE COMPUTER THAT MADE THE DISC
RATE ME PLEASE
Apr 16, 2008 | Car Audio & Video
Alpine CDE-7856 CD Player Logo
215 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
