Question about RCA D52W19 52" Rear Projection Television
HOW DO I STOP MY TV FROM COM MING ON
MY RCA HDTV KEEPS COM MING ON EVER MORNING AT 7:00 AM CAN YOU WALK ME STEP BY STEP ON TAKING THE TIMER OFF. AND I DO NOT HAVE HAVE THE ORIGINAL REMOTE. I HAVE A UNIVERSAL REMOTE.
  • Anonymous Feb 06, 2008
    THIS IS LACEY 1 AND YES THIS IS MY TV AND I'M STILL HAVING THIS PROBLEM. PLEASE HELP ME. THANK YOU LACEY 1
Menu
setup
preferences
special features...right there just unchecked the square....
demonangel2190@yahoo.com
Posted on Feb 07, 2008
  • RCA Master
  • 5,138 Answers
Go to timer set everything to 0000 this should stop timer from coming on.
Posted on Feb 06, 2008
I have a 58' model LED58G45RQ and at a certian time at nite its coming on how do i fix this problem to stop having to get up and turn it off
Appears to be RCA TV.
The timer turns the TV/VCR on at a desired time. You can set it to
wake you up in the morning or remind you that a favorite program
is about to start.
1. Press MENU on the remote to display the TV/VCR MAIN MENU.
2. Press 2 to display the TIME menu.
3. Press 3 to display the WAKE-UP TIMER menu.
4. Use the number buttons to enter the channel number and time.
• After you enter the time, press 1 for AM or 2 for PM. Example:
For a time of 5:07PM, press 5, then 0, then 7, then 2.
• Press CLEAR to correct an entry or RESET to clear the timer.
6. To cancel the wake-up timer, first display the WAKE-UP TIMER menu by repeating steps 1-3 above. Then, press RESET to cancel the timer, and press MENU to exit. The timer is also canceled if MENU is pressed before step 4 is completed
RCA TV VCR COMBINATION User Manual Sleep Timer Wake up Timer Front Panel...
Mar 11, 2016 | Televison & Video
My seiki tv keeps shutting off?
Probably the set needs resetting. Call seiki and they will walk you through the steps.
Nov 02, 2014 | SEIKI Digital SE47FY19 47" LED TV...
How do i hook up a dvd to this tv
out the back of the dvd player there should be RCA cable connection that are labled OUTPUT ( audio Right and Left and video ) ( red,white and yellow ) --- now use RCA cables and from the dvd player connect them to the INPUT on the back of the tv ( audio Right,Left and Video ). and you should be good to go.
if you still are having troubles - please feel free to write back and ask me,,, I will do my best to walk you through any other steps.
c...
Feb 02, 2011 | Hardware & Accessories
Has anyone been able to find the Dish Network code for the L32HD31 32 in. HDTV LCD TV? Just moved my mother-in-law's tv to our house and would like to hook it up to our Dish network. Talked to the Dish rep...
Hey! I hope that you have gotten the remote code for your tv, but if not, here are the steps to get it working. The link below will walk you through a power scan, where you can scan through the codes until the right one is reached.
Power scan:
http://www.dishnetwork.com/SupportSection/power-scan-instructions
The second link is where you can go to address the remote with a list of codes. You can try either, they will both work for you.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Becki Barned
DISH Network Customer Service
Oct 05, 2010 | RCA L32HD31 32 in. LCD HDTV
Timer stopping
Dualit Limited
County Oak Way
Crawley
West Sussex
RH11 7ST
  • Telephone: +44 (0) 1293 652 500
  • Fax: +44 (0) 1293 652 555
  • Email: info@dualit.com
  • FAQS can be found at http://www.dualit.com/support/2-slice-newgen/faqs#question2 and new timers can be ordered.
    May 25, 2010 | Dualit Vario 2 Slices Toaster
    I was watching tv and the screen went blank. It
    You would have to try an INIT and see if it causes the tv to be operational again. It is something that you have to be walked through step by step by step and can erase the memory of the tv if done improperly. Call Sharp tomorrow morning at 9AM CST and someone can walk you through one. Call 800-237-5277 or if you have an aquos advantage model call 87-332-7867
    May 15, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
    D52w19 rca hdtv.will not tourn on. when u push the
    Hi Friend,
    Please folliow the below steps one by one
    Step 1: Turn on the TV
    Step 2: Hold the ON/OFF Button for 10 to 20 Secs
    Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
    Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
    Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
    If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
    Even after that you are facing the same issue please check with the Display Card in the TV,
    If you have any Clarification please feel free to contact us
    Regards,
    Ayyasam
    Apr 03, 2010 | RCA D52W19 52" Rear Projection Television
    WD 62725 Timer geen light keeps blinking
    Here is how you fix the problem. Turn off the power to your TV for 10 seconds, then turn on. Next, take a paperclip and push in the reset button for 10 seconds, then release and wait until the light stops blinking - may take up to 5 minutes - be patient. Then turn on your TV as normal and your problem will be fixed.
    May 26, 2009 | Mitsubishi WD-62725 62" Rear Projection...
    My tv won't turn on, the timer keeps flashing
    http://www.jyerdon.com/tv/
    If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
    buranc@bellsouth.net
    Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
    RCA HD50LPW175 50 in. HDTV
    IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
    http://servicemanuals.vstore.ca/
    Dec 25, 2007 | RCA HD50LPW175 50" HDTV
    RCA D52W19 52" Rear Projection Television Logo
    43 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
