FixYa.com
Tags:
Monitors
Generic problem for all Monitors
Line shadows on my monitor
posted by vapawv on Jan 19, 2008
why does my monitor have shadows
Comment by vapawv, posted on Jan 19, 2008
can anyone help with line shadows on my screen
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 04, 2008
Not Rated (0)
Jordo_6
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
it could also be the cable you are using, unless it didnt used to do it, cause i've had that problem and it was the cable
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 20, 2008
Not Rated (0)
kishkane
Rank:Wiz Wiz
Rating: 72%, 97 votes
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
This Problem Also Relates To: HP Compaq FP5315 (Black, Silver) 15" LCD Monitor HP A4331D 20" CRT Monitor Philips 107E56 (Black) 17" CRT Monitor HP 91 (White) 19" CRT Monitor Philips 170C4FS (Silver) 17" LCD Monitor Philips 170P (Silver) 17" LCD Monitor HP Pavilion MX70 (Gray) 17 in.CRT Conventional Monitor
Can you Help with these Monitors problems?
Star Logic 17 inch LCD Monitor
i am tryin to coonest
i am tryin to coonest my HP... Answer This...
Monitors
screen on monitor very dark
Do not know how to adjust my... Answer This...
Polyview S17E 17" LCD Flat Panel Display With...
Grey then screen goes blank on...
As soon as I attach the powr is... Answer This...
Toshiba P000232050/F 13.3" LCD Monitor
interference lines and patterns...
I have noticed what seems like... Answer This...
Samsung SyncMaster 204B 20.1" LCD Monitor
monitor
we have had this monitor for a... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
