Disk error when trying to finalize disk - Televison & Video
  • 7 more comments
  • Anonymous Feb 16, 2008
    disk error for philips dvd cd combo same as other post and cleaned it but still won't read the disks and seems to blame it on the disk even though disk was playing fine other night.
  • monimom3 Mar 09, 2008
    I have tried cleaning the disk player,moving to a completly level surface,changed recording time,changed disk brand.
  • BARBMC70 Jul 08, 2008
    WHEN WE TOOK THE DISK HOME TO PLAY,IT WAS BLANK.THIS HAD HAPPEN AFEW TIMES BEFORE,SO WE MADE SURE WE WENT THROUGH ALL THE STEPS.THIS HAS HAPPEN ALOT OF TIMES.
  • bwhite08 Jul 18, 2008
    disc error on formating and then does not recognize disc. still looking for solution
  • classy106 Jul 24, 2008
    I'm getting the "no disk" error message for every type of disc. Has anyone been able to get this repaired with success. My machine, RSQ E500, is not under warranty any more. Any recommendations? Thank you
  • Paul Dumont
    Paul Dumont Jul 29, 2008
    Will not read any disc. I was in electronics for some 50 years and I did all the normal stuff such as cleaning and bring the codes up to date and it will not get out of that mode. Maybe it's time to give up the RCA line.
  • jbischof Aug 06, 2008
    Have a Sony GX-315 DVD recorder that will record & Finalize. But disc will not play on any unit even the GX-315
  • Anonymous Jan 06, 2009
    SOLUTION: PITCH RCA IN TRASH AND GO WITH A DIFFERENT BRAND AS I DID. PANASONIC
  • snwflake10 Jan 27, 2009
    I receive an error when trying to finalize the dvd. I use dvd+r. Only happened lately. Used to work fine.
I just bought a replacement dvd recorder for one that stopped finalizing and even recognizing dvd's it had created, now this new one doesn't like the blank dvd's I have right out of the box, it will record up to the point where it should be able to finalize them but then says, can't write to disk. All the information is there to play the dvd, just can't be read by itself or other stand alone players.
Solution, IsoBuster, by SmartProjects. It will scan an unreadable dvd and allow you to extract the files it can and sometimes can't filling damaged sectors with dummy blocks, or skips them where there are scratches. These files can then be burnt to another disc on your pc using ImgBurn which is free. i just rename the vob files which are the video files to mpg, then I can do what ever with them, use Nero to make dvd's or vcd's for friends.
Posted on Mar 23, 2008
How do I fix this problem every time I try to burn a CD it works until finalizing the disk?
Posted on May 05, 2009
What does error code e22 mean
e22--will not finalize DVD-R disk (due to dirty lens, I think)
*unplug unit and replug after 20 minutes
*restore settings if needed, and reset clock
*insert & run/play a DVD lens cleaner disk
*dub video from the HD to a NEW BLANK DVD
*finalize after dubbing is finished
THIS WORKED ON MY MAGNAVOX MDR 533H/F7
PS: make sure that the new blank DVD disk is from the same pile of disks that you were able to finalize before.
Feb 08, 2016 | Magnavox ZV427MG9 DVD Recorder/ VCR
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
"Wrong Disk" error
I would assume that you finalized the disk after you burned them. THat being the case try the disk on another DVD player. If that does not work try burning another disk. Its possible that its either a failed burn, a picky DVD player or plain defective disc. So the only option left is to isolate the probelm.
Oct 04, 2008 | Memorex (3202-5639) (50 Pack) (32025639)...
Format Error code C:13:01
this camera is a gem! try finalizing the disc using nero burning software or any alternative. but dont try this on the disc that has your important pictures for safety reasons.
Jul 18, 2008 | Sony Mavica MVC-FD200 Digital Camera
Finalizing
IF THAT DISC WAS RECORDED ON AND THEN REMOVED BEFORE FINALIZING IT WILL NOT FINALIZE. THE CAMERA LOOSES THE MAIN INFORMATION TABLE FOR THAT RECORDING. ONLY THING TO DO NOW IS, IF THE DISC CAN STILL PLAYBACK ON THE CAMERA THEN CONNECT IT TO A DVD RECORDER VIA THE AV PORT AND RECORD.
Mar 30, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Sony Mavica MVC CD500
It comes that Disk not being recognized. I had the same camera before. You need to use good quality CDRs or CD-RWs. Usually Sony Mavica disks best with that camera. Maybe you cannot find Mavica in market then go for Sony, Philips, Imation miniCDR/W. also keep the lens of the internal CD writer clean. If you need further assistance please post your question
Good Luck
Mar 05, 2008 | Sony Mavica MVC-CD500 Digital Camera
Error code number 0901
IF THAT DISC WAS RECORDED ON AND THEN REMOVED BEFORE FINALIZING IT WILL NOT FINALIZE. THE CAMERA LOOSES THE MAIN INFORMATION TABLE FOR THAT RECORDING. ONLY THING TO DO NOW IS, IF THE DISC CAN STILL PLAYBACK ON THE CAMERA THEN CONNECT IT TO A DVD RECORDER VIA THE AV PORT AND RECORD. SORRY COULD NOT FIND THAT CODE IN THE SERVICE MANUAL.
Feb 10, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Sony DVD201E
Iv got same problem, cant open door..got disk error 1st then drive error next
Nov 29, 2007 | Sony Handycam DCR-DVD201 DVD Camcorder
Disk error c:13:00
A substantial percentage of my Memorex 3.5" CDs won't finalize, and when I susbsequently try to review the photos on the camera, it tells me there are no files on it. Nothing will download to the computer via the USB either. A substantial percentage of my Memorex 3.5 "CDs won't finalize, and when I susbsequently try to review the photos on the camera, it tells me there are no files on it. Nothing will download to the computer via the USB either.
There is a software program that always saves me when I get careless and fill the disk to full. It''s called CD Roller. It''s called CD Roller.
Nov 09, 2007 | Sony Mavica MVC-CD400 Digital Camera
Televison & Video Logo
717 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
