Question about Gateway FPD2275W LCD Monitor
Screen shrinks my monitor(envision 19inch pixie 750 monitor (model x-754f) will click and then the screen will shrink and i will loose about 1 inch on eather side. I would come back out to a full screen if i tapped on the sides but now it won"t. Sometimes it will be full screen for a couple of days and then all of a sudden it will shrink again.
  • magruff5 Jan 19, 2008
    any other ideas i tried the above suggestion but it didn't help.
  • Anonymous Mar 08, 2008
    First I ike to thank the nice service, especially the deep explanations.
    Shapo.
    I've got a LG Flatron 775FT (year 2001). A good pannoramic screen.
    Now to my problem:
    First there where noises (from the inner contactors ?) when starting the computer, and the colour got a bit dull. And after some days the screen shrinked to about half its width..
    I opened it and cleaned with a brush and a dust cleaner (was much deart).
    Now,  the noices did disappear but the shrinked shape  )(  is still there.
    Question:  Is it safe to play with the screen while its back cover is off ??
    Thanks,
    Uzi.
    P.S.
    nVidia (card and driver) only offered and opperated it with 60 hz ,
    while Radeon 7000 with tnn driver enabled 60 to 100 hz ..
    The noices appeared with both cards, but the shrink happened some days after swithing to 100 hz (with ati).
    And as said above, the noices vanished only after the cleaning.
    Scholar:
  • 67 Answers
Possibility: Dust accumulated within.
Disconnect the monitor, and open it up. With a dry small paint brush and a vacuum cleaner, remove as much as possible. Especially around the tube and the ultor (the cable connected to the rear of the tube, usually has a rubber cup- like fitting on the tube end), then close up and test again.
Still doing it? This part requires great care, if you don't feel confident about working around a live chassis, DON'T!!!
Disconnect and open the monitor again. Connect up without its cover. Look around the chassis, you will see a number of adjustment potentiometers, possibly with markings such as "width" and "height" etc. Turn on the computer, and with a PLASTIC adjustment tool or TV alignment tool, (you can make one from a plastic knitting needle even), carefully MOVE each of these adjustments a bit, THEN RETURN THEM BACK TO THE POSITION THEY WERE IN.
Dirt often causes these controls to become intermittent in their wiper contact to the track.Moving them can restore a better contact.
There is also available fron electronic component suppliers, a pressure- pack contact cleaner product that can be sprayed onto/ into these controls, and may help if moving them does not.
If the above does not cure the problem, there is probably an electronic fault.
Remember, if you don't feel confident about poking around inside live equipment, DON'T, maybe you have a friend or relative who knows how.!!
Posted on Jan 19, 2008
  • Ray Murphy Jan 19, 2008
    Okay, if it's not dirt, maybe a "dry" or fractured solder joint. Can be difficult to find, gently flexing the PCB (with something insulated, keeping hands clear), might locate the problem. The cure if you find a "tender" area on the board, especially around the line output transformer, is to carefully examine the joints with a magnifying glass, and resolder. It can be beneficial to resolder almost all the joints in the general area. Care must be taken to not create solder bridging between joints, or you will create problems.
    Beyond that, dried- out electrolytic capacitors are a possibility. U will need test equipment (ESR meter) to locate, else substitution with new components. But this is tech work!
    Good luck, this is all I can suggest.
How do you shrink the font size?
... on a mechanical (manual or electric) typewriter?
Unless it is a IBM Selectric or equivalent, I dont think you can shrink the font. With a Selectric, you don't actually 'shrink' the font as we understand "shrink" it today, what you do is change the 'element' for one with a smaller 'pitch' and/or smaller font. Standard pitch is 10 or 12 pitch (10 or 12 letters per inch).
I am answering your question based on what you are asking. If you really mean to ask something else or If I misunderstood your question, please post a comment here so I can give it another shot.
thanks
a
Dec 08, 2009 | Computers & Internet
Horzontal picture shrinking
The monitor is "dying". Since it's only 15 inches, and since it's a CRT, it's time to responsibly recycle the monitor, and buy a new, 17" (or larger) LCD screen.
Nov 17, 2009 | Philips SoHo 105E 15" CRT Monitor
Can sirius antennas be cut and spliced back together
If your antenna cable has been cut or severed, it can be repaired without the need for a replacement.
You will need the following things:
Small 600 degree soldering iron and solder.
Liquid flux for soldering the braid.
Small sizes of heat shrink tubing.
Small heat gun.
Small pliers, cutter, and Xacto knife.
1) The first step is to use the Xacto knife to cut both ends of the antenna cable so you have a clean end.
2) Using the Xacto knife roll the cable on a board and gently cut all around the cable to cut the outer insulation. Remove about 1/2 inch of the insulation from each end.
3) Push the braid back to expose the center wire and gently roll the cable and cut the center insulation to expose about 1/10 inch of the center wire. With your small long nose pliers, bend the center wire into a small hook shape.
4) Repeat all the above steps on the other end of the wire.
5) Put a 1 inch piece of heat shrink tubing on one end ( the black piece), and a 1/4 inch piece of heat shrink (the white piece) on the center conductor. Look at the picture to see this.
5) Hook the two ends together. Gently squeeze the hooks closed and solder them together. Be very careful when soldering this. Be quick so you do not apply to much heat and cause the heat shrink tubing to shrink on the side where you do not want it to be.
6) Slide the small white heat shrink to cover the cooled solder joint you just made and use the heat gun to shrink the tubing in place.
7) Now push the braids back together to cover over the connection you just made. Try make the braid smooth together by GENTLY rolling the cable between your fingers. Carefully solder the braid. A little liquid flux on the braid prior to soldering helps the solder flow and makes it look better.
8) Slide the final piece of heat shrink tubing over the braid and shrink it with the heat gun.
Jun 12, 2009 | Sirius Satellite Radio Receiver
My sirius car antenna cable got cut by the trunk closing on it. I tried connecting the two ends and the system can not get a signal. What can I do?
Small heat gun.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 07, 2009 | Sirius Satellite Radio Receiver
Wide screen problems
I guess the video board or logic board is having problem.
Apr 24, 2008 | ViewSonic VX1935wm LCD Monitor
Zenith console tv model sentry 2 27 inch
Resolder the vertical deflection section. Change pump up capacitor if it has one...100uf is a typical value. Is the vertical output some flavor of LA783x ?? May need to replace. A model # would help.
Nov 04, 2007 | Televison & Video
56v-Screen shrinked horizontly
You need to service your monitor. Give it to an authorized service center.
Dec 15, 2006 | SAMTRON 55V 15" CRT Monitor
Shrinked picture of 29 inch television.
It is a pincushion problem. There is a bad cap and or a bad diode in the horzontal section.
Oct 29, 2006 | Toshiba 27A51 27" TV
Gateway FPD2275W LCD Monitor Logo
120 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
