Question about Teac (DW-224E) DVD Drive
Disc won't eject
I have Bose model AU28 Media Center. I inserted a DVD disc. It played for 7-8 minutes and then stopped. I have attempted to eject the disc. It won't eject.
    Master:
  • 619 Answers
Hi, to open thje the disc tray , look for a tooth pick , insert small hole in front panel push and back until disc tray out. , motor belt need to replace.
Posted on Jan 20, 2008
The disc on the drive cannot eject.how can i fix it?
Posted on Apr 29, 2009
6ya staff
SOURCE:
Drive Reads & writes CDs but only reads DVDs. Attempts to write a DVD ejects the disc with a 'insert writable media' prompt. Device manager says driver 'up to date'. Am I using the...
my desktop computer will not write to a dvd, but will play a dvd
& my laptop will play a cd but will only write to a dvd
it's just the way the drives are,,I've tried different types of dvd also nothing helped
Sep 07, 2011 | Computers & Internet
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
DVD drawer will not open - stuck dvd inside
My only suggestion is to press and hold the eject button for a period of time (15 - 30 seconds). This might unlock the drawer. If not, I would contact Bose Customer Service directly.
May 15, 2010 | Bose Lifestyle 28 System
Dvd wont eject when you try to open it. or dvd wont play
i think the cd or dcd disc inside stuck-up you have to insert the tiny hole located at the dvd rom and insert a needle or something that is similiar or smaller of the hole size of that locted in your dvd rom.usually its new the LED blinking when opening or inserting the disc. and now you can now eject your disc manually regarding your question about it won't play a dvd try first to clean your DVD disc with a micro fiber cloth, avoid you'll scratch it, if still the same i think you're dvd room is defective.
Oct 08, 2009 | Bose (321GS) System
I have a lifestyle 18 bose system which only plays region 2 DVDs. How can I get it to play region 1 as well?
Hi, check below the media center/DVD player as to what region your system was fixed into (indicated by a number inside a globe). This is located underneath the unit just beside the serial number. FI the system indicates that your system indeed is set to region-2 then proceed as follows. IF it marks a different number region, then bring the unit to the Bose service center.
Steps in UNLOCKING REGION CODE of media center:
1. Load a DVD and wait for the display to show "REGION CODE ERROR, CONTACT BOSE"
2. Once this comes out, press eject button on your remote control but do not remove DVD disc
3. Press the following button commands in sequence (make sure they are in sequence and are pressed by looking into the media center display where a small green dot should blink indicating that each command is received).
4. First you need to initiate the system region change on the remote control:
a.while the tray is out and the DVD is still in the tray, press and release "RIGHT" arrow button
b. then press and release "UP" arrow button
c. after, press and release "SHUFFLE" button
d. then press and release "STOP" (black square symbol) button
e. lastly, press and release "MUTE" button and system should go on mute (indicated in the LCD display
After this, you now can change the region code by doing the following button press on your remote control:
1. While the DVD tray is out still and the DVD disc is in the tray, press and release "STOP" button (black square mark)
2. Press and release "SHUFFLE" button
3. Press and release number "0" button on numeric keypad
4. Lastly, press and release "ENTER" button on your remote control and the DVD tray should go back inside the DVD. The disc then should start loading and playing resumes.
5. Allow the DVD disc to run for a few minutes (if you want enjoy a full movie) to keep the region change resident before switching off again.
Now enjoy your Bose Lfiestyle DVD System REGION FREE!!!
Do note, this does not apply to Bose DVD system that are locked to region-1
Glad to be of service always!
Mar 03, 2009 | Bose Lifestyle 18 System
Stuck Disc
I sould hope by now you have already taken your set to be repair your gears inside are either broken or striped .blessing from belize goodluck.
Mar 18, 2007 | Bose 3·2·1 II System
This system stopped playing DVD with a very slight use
1. An unplayable disc is inserted. 2. The Rating level is set, Cancel the Rating function or change the rating level. good luck!
Jan 12, 2006 | Toshiba SD-V55HT System
Open Questions:
toshiba terca m1 can the teac dw-224e-36 drive be replaced with a dvd burner drive? thanks, brent [email protected] 732-754-3371 The problem with replacing the original CD drive in these notebook computers appears to be a serious "large-scale" problem. When you replace the CD drive with another Manufacturer and/or Model the Recovery CD and associated software can't find the exact drive ID its looking for. It then refuses to proceed with the software reload to bring itself online and function properly. This is called "forcing the customer to come to the original manufacturer only" policy and paying whatever they demand to get a replacement that will work properly with all the original system CD's. I'm sure the Boot EPROM has the DW-224E-36 ID burnt into it to ensure it doesn't load alternate drivers. We all hate to pay $150 - $190 for a drive we know cost approximately $20 - $30 to make. When you make 5,000 to 15,000 of anything every week, the actual manufacturing cost gets incredibly low. I've been chasing an answer to this problem for a Toshiba Satellite A25-S207 system needing a functional DW-224E-36 DVD ROM CD R/W drive because it won't read the Recovery DVD to load the software onto a new HardDrive. The Notebook is literally "like new" but the HardDrive and CDROM drive are disfunctional due to overheating. The cooling airway pathway was totally blocked with "lint" and the owner never thought to have a professional look at the system. I wish us all "good luck" finding a seller that is satisfied making a "reasonable profit". All I've thus far been able to find are sellers wanting to triple, quadruple or 6X their money on anyone that relies solely on a notebook computer. Toshiba wants $188 for a replacement. Then add state tax and shipping to pay over $200. This is outrageous for this product and the PC owner will probably have to throw the unit away as she can't afford it. $100 for a new hard drive, $200 for a new CD drive, $100 for a new battery and $100 for 1GB of new RAM (remove 2ea-256MB small DIMM's and replace with 2ea 512MB small DIMM's). This doesn't have any labor included with the costs. I'm doing the repair as a friend to the owner's family. $400 is minimum to cover the "need", the extra RAM is a "want". The real loser's are the PC owner and the world we live in because we have another 10-14 lbs of "electronic & plastic scrap" to bury in a hole somehere and she has to figure out how to fulfill her computer needs affordably. Goood Luck to all. JRCjr 12-28-08 (I would appreciate whomever owns this website to not make my email address viewable by the general public). Should someone have a better answer I am open to suggestions. [email protected]
Feb 26, 2017 | Teac (DW-224E) DVD Drive
Teac (DW-224E) DVD Drive Logo
776 people viewed this question
Top Teac Computers & Internet Experts
Ekse
k24674
Alun Cox
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
