I would first try resetting the breaker or unplugging the unit for a minute or two and see if that yield`s any success. If not...
Try holding the door switch pushed in.(or held closed in electrical terms) This may require a second person if you can`t reach the clock/timer while engaging the switch. With the switch held, set the unit for self-clean, let the lock advance to a "locked" position and once it indicates it is locked press cancel while still holding the switch closed. This should in theory force the lock to advance to it`s open/unlock position.
Hope that help`s. If so please rate the solution I provided.
Thanks for visiting fixya and good luck.
macmarkus :)
SOURCE: Self clean door lock will not release
what model do u have can u try to push relly hard the lever ove rto right again
SOURCE: frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
SOURCE: The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
