Question about Wurlitzer Jukebox Princess 120-Disc CD Changer
Cd not playing
When the CD started to play, it plays for only four or five seconds and then it stops playing and returns the CD back to the carosel. Now, there is a flashing number in the play selection screen and it won't retrieve any CDs at all. How can I test the CD pro function and make a determination if the CD laser is bad or if the digital board is bad? Where can I order parts to fix it?
  • AVES Jan 24, 2008
    the wurltzer is new ...all the discs are new... now the machine has a no. 104 on the selection screen ...and now the machine doesnt respond to any selections
  • 107 Answers
Look for any damage of your dics, maybe some of your dics are scratched or has a dirty part. hope I helped you.^.^
reply me if still it has the problem. so we could proceed at the next step.
Posted on Jan 23, 2008
  • Mark Payas
    Mark Payas Jan 24, 2008
    try to change the optical eye or adjust the variable resistor on the optical lens.
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
Nikkai car stereo
The CD player is failing to track the CDs accurately and is likely to become more erratic over time.
Dec 03, 2013 | Computers & Internet
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Changer will pick up CD and spin for about three seconds stop, set still for about four seconds. CD will not spin again reject CD back into the rack. the above will happen again but during the four second...
This sounds like an issue with either your CD player, CD control board, or Selection and Credit Computer. I can help you troubleshoot further over the phone (and repair/replace whatever is necessary). My name is Rod and I can be reached at tech@wurlitzer-ohio.com. Please email me and I'll email you my telephone number.
Jun 18, 2010 | Wurlitzer Jukebox 1015 One More Time...
Good day - I moved for my work and upon
First clean the laser head with a Qtip and alcohol. It gotta be perfectly clean, so wipe with fresh brand name qtip and make sure there is not a single dust particle on it. You gotta remove the cabinet with star screwdriver. Your beam might be tired. First try with the clean up! Unplugg before opening!
Oct 12, 2009 | Yamaha CDC-665 CD Player
Do All DVD Players Also Play Music CD's
All DVD Players will read and play CD players
Nov 16, 2008 | Hitachi GD 7500 Internal DVD Drive
Vocopro Gig Man won't play
we're having probles.we have avhf-4800 from voco pro,lights come on the box and on mikes no sound on teo mikes
Jan 09, 2008 | Audio Players & Recorders
Wurlitzer Jukebox Princess 120-Disc CD Changer Logo
97 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
