Question about Whirlpool RBS305PD Electric Single Oven
WHIRLPOOL OVEN we self cleaned our whirlpool oven and it now won't heat. i checked the thermal fuse and it was bad. i replaced it and it still won't work. any solutions? thanks, Barry
  • 6 more comments
  • zzsboat Jan 19, 2008
    I have the same problem, it started all of a sudden. sounds like a overtemp condition but the oven is cold. And the door is locked. zzsboat
  • txpal Jan 19, 2008
    yes i have 220 to my oven. the oven will turn on and go in to pre-heat but never gets hot. i did check voltage to one of the elements but did not have any.
    i have ohmed out both elements and they are good. yes i tried to run the broil element by itself and it does not work. i do have 110 to the terminal block.
    i checked and i had no voltage drop at all. also on the terminal block you have these 3 white wires. 1 of them goes to the control and the other 2 go to the back of the oven. i don't have the oven puuled out at this time so i haven't traced where they go. my question is when the oven is turned on should i then have voltage to the terminal block where those 3 white wires are hooked up? if so i don't.
    yes i do have a tech sheet. i do also have 110 from white to both legs. i did not ohm the new thermal fuse. i will do that. i'll have to pull the oven back out and remove the cover to get to it. if it ohms out ok then what?
    hey you just fixed my oven. i'd never thought it would have been something like that. (the reprogramming) now i can go eat lunch and enjoy it.
    thanks
  • bob in sc Apr 15, 2008
    i ran self clean on my oven and now no heat from either the bake or broil elements. What fixes this?
  • Anonymous Mar 12, 2014
    I have an Whirlpool oven and every single time I use self clean the thermal overload opens and then elements will not work. I have replaced several times. thinking of just bypassing overload thermostat.
Nice, it'd help me a lot thank you
Posted on Jan 19, 2008
    President:
  • 1,314 Answers
Have you checked your in coming power the clock will work on 110 but it takes 220 for full function zzsbolt yours does sounds like a thermal fuse
  • 5 more comments
  • robert samples Jan 19, 2008
    that sounds like your not completing the circert do you have the tech sheet wiring diagram for that unit line one comes in to the clock its split there and by reley either goes to one side or the other of the bake or broil element line two is on the other side of the thermal fuse did you check the wires at the terminal block its self and have you ohmed the element its self and have you tried to see if the broil element will work by its self will help find the problem
    next thing id try is a voltage drop test go to your terminal block and check the incoming power like you were just checking the voltage have some one start the range and see if the voltage drops off if it drops more than 10 percent you have a bad breaker or loose connection
    no in a 220 system white is neutral blk is 110 red is 110 orange is 110 green is grd or neutral also do you have a tech sheet on this unit if not i can e mail you one they are to big to send from the site now from black to white you should have 110 and from red or orange to white you should have 110 also did you ohm the new thermal fuse before you put it on ive seen them bad from the box however we will fix this unit
    before that shut down the power and run the tests under the thermal fuse chart can check it all there with out pulling out the oven then go up to the top of the page to programing oven cavity size matter of fact id try that first
    great ihats what were here for when you lost power the eoc didnt know it hadnt been changed as it has no back up battery like a computer thanks
    reamber that if your power fails and you can change my rating to a fix ya it will help the site
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
I have a Whirlpool Gold self-cleaning oven w/convection. Following a self-cleaning cycle the oven will not heat up. Is there a certain amount of down time that has to go by before it will function again...
The self-clean cycle has blown a fuse in the rear of the oven. That thermal fuse must be replaced. Go to www.appliancepartspros.com and enter your model number. Find the thermal fuse on the diagram and then you can orfer the fuse from them.
Aug 27, 2011 | Whirlpool Ovens
My oven stopped heating after using self clean.
all whirlpool ovens have a thermal fuse on the back that will break when the oven gets to hot replace it and you will be working again
Apr 03, 2010 | Whirlpool RBS275PD Electric Single Oven
After doing a self clean on a whirlpool oven model rbs245pd06 it will no longer heat on bake or broil.
Unfortunately you have found out the hard way about the self cleaning feature... they cause many problems...
Here is a tip that I wrote about that and it includes some things you can try to get you oven to unlock...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Mar 30, 2010 | Ovens
Whirlpool oven stopped working after self cleaning
If the display still works but neither the Bake or the Broil elements wont heat up, it's likely that the Thermal Cutoff has opened and has not reset itself. This is a common problem after self Cleaning.
The fix is to replace the Thermal cutoff which requres you to pull the oven and remove the back panel to get at the thermal cutoff.
What happens is that in Self Clean, both Broil and bake elements are used and the oven gets so hot that the middle skin (between the oven liner and the back panel, where the thermal cutoff is mounted gets so hot the thermal cutoff operates. It should reset itself but sometimes doesn't and then you have to replace it.
Nov 17, 2009 | Whirlpool RBS305PD Electric Single Oven
Whirlpool 27" wall oven. no heat after self clean
Self cleaning features are not recommended by most appliance technicians. The ovens are not constructed satisfactorily to expel the 1000 degree heat, Therefore the thermal fuses blow as well as other parts failures.
Remove the oven. Remove the rear panel. Replace the thermal fuse in the back of the oven. Use Easy Off next time.
May 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
The Oven won't heat up
the thermal cut off located on the back of the oven has probably tripped,common problem. replace thermal cut off.
Dec 19, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Mar 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool RBS305PD Electric Single Oven Logo
723 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
