Question about Acer Aspire 3050-1733 Notebook
3050 will not boot
My aspire 3050 will not boot. The light comes on for about 2 seconds, then goes off. I have taken the battery out and held down the power button for 20 seconds...this did not help. Is there something else I can try before sending it to be worked on?
    Problem Solver:
  • 4 Answers
Try a different power supply. Plug in the AC with the battery out.
Posted on Jan 19, 2008
Bios password reset scer 3050
Try removing the main battery and unplug the power, then hold the power on button down for 30 seconds, if this does not work, remove the cmos battery for 30 seconds to reset the bios
Apr 01, 2013 | Acer Aspire 3050-1733 Notebook
My acer aspire will not boot up. After starting the process it flashes a quick screen with an error for registry file failure and restarts boot process
As it starts up.. hold down F8. An option for a Safe Mode should be available. You should choose that and once you get through to Windows go to Start > Run and type in "chkdsk c: \r"
Jul 07, 2011 | Acer Aspire One PC Notebook
My Apple mac book pro will not boot up. I have a grey screen. I've taken out the battery held doen the on button for 5 seconds and re connected it nut I've still got a grey screen. Help
The grey screen is the bios of your laptop is booting, this is freezing for some reason.
Do 3 things.
Try holding power button down for longer at least 10-20 seconds.
do a PRAM reset, apple symbol, alt P & R keys all held on boot up.
Do a smc reset.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Apple MacBook Pro Notebook
My toshiba r10 laptop wont turn on the green power light to the front is on but the yellow battery light only comes onn when i plug in the power cord to it and it only stays about 2 seconds
Ok here's what you will do
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Tablets & eReaders
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
My Acer Aspire 3050 laptop can not boot
Hi
Thank you for your query
unfortunatley you are stuck in a windows loop and will need to reformat your PC
Please do the following to reformat
1) Put your recovery disc into your PC and allow the PC to restart
2) The laptop should pick the disc up and boot from it
3) Follow the onscreen instructions to complete the rest of the install
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 17, 2010 | Acer Aspire 3050-1733 Notebook
Acer Aspire 3050 will not boot - LEDs flashing 8 times
My Gateway did that it was due to the power adaptor being loose on the motherboard. Push the cord in and rotate it and continuously push the power button if it starts that is your problrm. You can temporarily fix it with tape once you discover where the cord wants to be or you can use a clamp.
Aug 26, 2009 | Acer Aspire One A150-1006 Notebook
Lights come on but no fans or powerup
Please follow the steps below.
1. Please removed the battery and unplugged the power supply.
2. Held down the power button for 45 seconds.
3. After 45 seconds reinstalled the battery and the power supply and pushed the power button and if it works then you don't need to replace your motherboard.
4. Else try it couple of times or up to five times before it worked if worst comes to worst.
Thanks
Aug 26, 2009 | Acer Aspire 5050-3242 Notebook
Black, cannot boot up... etc.
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 02, 2009 | Acer Aspire 5520-5908 Notebook
Acer won't boot up
when any computer posts/boots up.
it goes through a sequence of initialising things before booting.
i,ve been repairing computers for around 12-15 years.
1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
Thankyou for using fixya.
Mike @ compurepair.
Apr 20, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 3050-1733 Notebook Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
