Everytime you win a tennis match, your skill level will go up. The higher the skill/the strength of your wins will determine what skill level you face next. Bowling skill ranks are determined on how well you do in each game. Once you reach PRO, you get a sparkling ball. Keep trying at both Tennis and Bowling and you should see your skill rating start to rise. Good Luck!
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide,
that explains step by step to fix the problem without any technical
knowledge. I hope this guide will solve your problem. It also gives
information on fixing many Wii Related Problems, so its a kind of Wii
Problems Reference Fix Guide.
For Shrek I don't know, but for Wii tenis, I know that you can set the players to be cpu or player conrolled. I guess your daughter has set all of them to be controlled by the cpu. I think when you're setting up a game in wii tennis and you see all the players standing on the court (still in the menu screen) check to see if it says player or CPU.
@ Slivic22 Some games does not use Sensor Bar pointing because they play with motion/accelerometer only. After you select the number of sets on Wii Sports Tennis, there is no Sensor Bar pointing except for Pause menu. That's because you Swing the remote like a racket.
well i have the same problem , i have tried everthing so i just feel sorry for u knowing that u cant play on ur Wii so if u do get an answear could u contact me at" [email protected]
you sensor bar is likely not working write because the wii contrl was going to fast and to close to it at the same time + the impackt must have hurt the main cesor inside of it
Have you tried the game settings?There is an option in the wii menu to adjust the wii mote to the sensor bar.Also make sure both are clean.Be sure the sensor bar is centered with the tv,and make sure you have fresh batteries.Hope this helps!
try syncing the remote (under the cover on the back of the wii remote where the battery's are there is a circular red button press it then on the front of the wii where you can put your SD card there is a rectangular button press it if that does not work then try doing it the other way around if that does not work keep trying if that does not work i dont know what will
