Question about Seagate Barracuda 7200.7 40 GB Hard Drive
How to install seagate ata IV hardrive
Hi i just got a 40 gig hardrive for my computer and i need some help on how to install it also i still have my old hardive with all my programs and music files is there a way i can transfer all that data on to this hardrive thanks
    Brigadier General:
  • 6,966 Answers
The easiest way to upgrade from your old HD to the new 40Gb HD is to clone the old to the new. Do a google for "hard disk clone" freewares. Personally I use Partition Magic and have had very good results.
Hardware wise, you need to install the 40Gb as a slave to the old HD by connecting the same IDE cable as that of the old HD (you may have to remove your CD/DVD temporarily). You also have to temporarily remove the single jumper of the 40Gb to allocate it as a slave to the primary master (old HD). Plug in likewise the 4 wire power connector. On power up go to your CMOS/BIOS setup to verify that your PC autodetect the 40GB (you may have to do a manual detection). Boot your PC and go through the normal boot sequence. Thereafter download your clone software choice, install and run. Follow on screen instructions. You may need to reboot. After completion, use Windows Explorer to verify that everything has been copied. Power down, remove the old HD, relocate IDE cable connector of the old HD to the 40Gb, reconnect your CD/DVD, and place back the jumper of the 40Gb. On popwer up go again to your CMOS/BIOS to verify that the 40Gb & the CD are detected. Save & exit, reboot.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 19, 2008
I connect my seagate external hardrive to my xbox to store some data on it because my xbox does not have an internal hardrive. So i figured i can use my portable external hardrive to my xbox, and it said i...
Either you have 50 gigs of stuff on there or your hard drive space is not being properly read. U might need to reformat the drive if necessary.
Meanwhile your xbox electronics may have a limit on the size of space - so if the drive has 200 gigs of space on it and your unit will only recognize 32 gigs, then that is all it sees and can use. Capiche?
Jun 16, 2017 | Seagate Computers & Internet
Hi, I have some troubles with my Baracuda ATA IV 20gb,so I need to download some softwear for this harddrive.Do you know weare I can find it? Thanks Allex Bulat
Hi
Hard Drive faults can rarely be repaired by downlading drivers. The drivers for almost all hard drives are already in any operating system.
Most hard drive faults are physical faults, such as bad sectors, controller board faults or shock damage.
Some apparent faults may actually be due to incorrect jumper settings. It is worth fully exploring all the jumper setting options available on this drive.
This drive is quite an old ATA drive and because hard drives work so hard spinning several thousand times per minute (yours is 7,200rpm), the older a hard drive gets the more susceptible it is to failure.
Your drive was probably manufactured in 2001 and is likely to have had a 3 year warranty when new, so it is long past its warranty period. This means that little help is now available to you from Seagate.
It is sometimes possible to download Firware Updates for certain hard drives, which can improve the performance of the drive. But Firmware Updates rarely repair hard drive errors.
You can find detailed technical information about your hard drive here:
www.seagate.com/support/disc/manuals/ata/100129212b.pdf
Available Firmware Update Information for Seagate Drives can be found here:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=207931&NewLang=en To check if any Firmware Updates are available for your drive, you need the full model number, which should be somewhere on the label (possibly ST380021A).
If firmware updates or jumper settings changes don't work, you may have to consider buying a new ATA hard drive.
I hope this helps.
Aug 27, 2011 | Seagate Barracuda ATA IV (ST320011A) 20 GB...
I have a Seagate Barracuda ATAIV model ST340016A 40 Gig HDD. I want to put it in an external enclosed drive so that I can format and wipe the drive. I suspect it has some viruses on it that are bogging it...
You do not need a driver, I suspect the Seagate hard drive may be faulty.
Try conncting your hard drive as a Slave drive in your computer, if the BIOS does not detect the hard drive then the hard drive is faulty.
Aug 11, 2011 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
What kind of hard drive enclosure would i need for a Barracuda ATA IV model ST380021A?
im not sure what you mean this hard drive should fit into a computer without a need for any extra enclosures just the normal leads if you want any further assistance
http://www.seagate.com/cda/products/discsales/marketing/detail/0,1121,381,00.html
hope this helps
Apr 19, 2011 | Seagate Barracuda ATA IV (ST380021A) 80 GB...
I need to upgrade from a 20 gig drive to a 40 gig or more in my Korg D 1600 recorder. Please give me the names of compatible drives for this model.
Hi Fun - Korg shipped it's own 40 gig model with the 3.5" third height Seagate mode lST340810A 40 GB Ultra ATA/100 drive.
Korg users have compiled a list of tested compatible HDs
Judging from the list there is nothing unique about these drives. You very likely could use any similar 40 GB 5400 RPM IDE. The most important detail is that you setup the drive jumpers as Master.
Good Luck,
Mikeywaf
Apr 06, 2011 | Computers & Internet
My Seagate Barracuda ATA IV model ST340016A runs for about 15 minutes and shut the computer completely down. I was told my drive is crashing and I should get a new one. can I just pick up any seagate or...
If I were you I would make sure your computer has no size barriers.. Some computer bios have
a maximum drive size that it will accept. Be sure to check this before purchasing. Of course you can always go with the same size 40GB, but your best move is to upgrade to a higher size.
Everyone has their opinion about vendors. If you ask me Drives fail just like any other device, so
get one with a good included warranty and back up your stuff. Look for speed and size and
make sure its the same I/O as your original.
MOST IMPORTANT : Verify your system can handle the size you wish to purchase
Jan 23, 2011 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Which is the correct jumper settings on Seagate Barracuda ATA IV 80 GB Hard Drive
Hello Please see the image below for correct jumper setting cmptrlink_16.jpg
Hope this helps, if so do rate the solution
Jan 15, 2011 | Seagate Barracuda ATA IV (ST380021A) 80 GB...
What type of hard disk enclosure wll work for a 40 gig Seagate Barracuda ata IV drive?
I assume you want an external enclosure for this drive. Hard drives are built to standard dimensions and have the same power and data connectors, so any enclosure designed for a 3.5-inch IDE drive would work. Here's one I've bought several of for myself and others, and it's been reliable. There are many more available from many vendors. Just be sure you get one designed for IDE drives or that will take both IDE and SATA. If you get one meant for SATA only, the connectors inside won't fit your drive. Which enclosure you finally choose will depend on which you think is best (based on price, appearance, reviews, or whatever you look for), but any one will work.
Dec 02, 2010 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
How to tell which jumper is master and which is slave
Master is 7-8 (the 2 furthest from the power connector)
Slave is no jumpers selected
Here is a manual for your model for reference:
http://www.seagate.com/support/disc/iguides/ata/cuda7200ig.pdf
Mar 28, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate Barracuda 7200.7 40 GB Hard Drive Logo
211 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
