Locked up on restart... How do I solve this mess????
Sony's Vaio line of laptop and desktop computers ship with the latest version of Windows installed. Even the best designed Vaio computer can sometimes malfunction, occasionally in connection with an error in Windows. Boot your Vaio computer in Windows' "Safe Mode" to disable potential problem-causing drivers and programs to help you troubleshoot and fix your Sony computer.
Windows XP Press the power button on the Sony Vaio computer, typically found in the top right corner of the laptop's keyboard panel or on the desktop's tower. If your computer is already on, press "Start" in the lower left corner of Windows XP and press "Turn off computer." A new window will appear. Press the green "Restart" icon. Hold down the F8 key on your Sony Vaio's keyboard as soon as your computer's screen goes dark. A new window, labeled "Windows Advanced Options," will appear. Choose one of the Safe Mode options listed. "Safe Mode" loads the minimal amount of drivers, while "Safe Mode with Networking" also loads your networking preferences. Press "OK." b> Windows 7 Press the Sony Vaio computer's power button if it's off, or restart the computer. Click "Start" in the lower left corner of Windows 7 and choose "Shut Down." A new window will appear. Push "Restart." Press and hold your computer's F8 key. A menu called "Advanced Boot Options" will launch on the screen once the restarting process is complete. Choose "Safe Mode" or "Safe Mode with Networking" and press "OK."
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
