Question about Samsung SyncMaster 550S Monitor
Remove cover viewsonic vx 900 monitor to change bulbs
Http://www.lcdpart.com/images/ViewSonic_VX900.pdf
Posted on Sep 12, 2008
How do you change the bulb on viewsonic monitor 19" model VX900? Where can I get a new replacement bulb?
Posted on Feb 11, 2008
What is the default display settings for VA1912w
Viewsonic VA1912w
Optimum Resolution 1440 x 900
VGA up to 1440 x 900 non-interlaced (max. 60Hz)
May 26, 2014 | ViewSonic VA1912wb Monitor
Dead on arrival need to open back cover
emtv_satc852, First visit YOUTUBE and watch some of them being pried apart at their perimeters around the four edges. That's how most of them are opened. Some people use an old CD or DVD disk, while some use thin blade screwdrivers. Try "lcd monitor disassembly" or "lcd monitor repair" on YOUTUBE. Good luck. Hope this helped. 12fixlouie
Feb 25, 2010 | ViewSonic VX2433WM 23.6" Monitor
I have a new viewsonic monitor. It says it should
right click on your desktop and go to properties> resolution> change it to 1600 X 900.
if ur not able to see any thing on your monitor, try disconeting all the cables and restarting the system.
Aug 05, 2009 | Computers & Internet
Viewsonic VG 900 displays briefly, then goes blank
What Usually causes these to go on and off quickly is one af a couple things.
Usually it is the powerboard not putting out enough power to run the video board and the inverter.
Sometimes it is the actual inverter board. I have seen a plain small fuse stop these cold.
Rarely, but it could be a bad bulb in the screen. Bad bulbs usually start dark in the middle, or they start off pink. They can also flicker while they are on.
If you can take it apart and have a dc tester, the problem may be able to be found.
I repair some viewsonics , mostly VXs series, but I have done a couple of these.
bammbammfran
Oct 11, 2008 | ViewSonic VG900b (Black) (10 Pack) Monitor
Help needed!
it's probably a problem with the backlight or the backlight inverter... i had the same problem just a little while ago. If your electrical components savvy, you might be able to find the problem on the inverter (which is on the side of the monitor once you get inside). Otherwise look into replacing the bulbs (which are on the top and bottom)
Dec 27, 2007 | ViewSonic VX900 19" LCD Monitor
The screen resolution
Your going to love this. Open control panel, open display. Click the settings tab. Click Advanced. Click the Monitor tab. Remove the check mark from "hide modes". Click the drop down menu & set it to 75 hertz. Click Apply & than ok. You are now back to the Settings window. At Screen resolution move the slide bar to more. Pick what you want. Again click Apply & than ok. Bingo there you are! Have a nice day.
please vote...
Nov 18, 2007 | ViewSonic VA1703wb Monitor
Ati radeon 9600 video card
what you have the ATI card hooked up can you see the boot screen? If you can see that you might want to try going into safe mode and making sure your graphics settings aren't set beyond the capability of your monitor. If you can't see the boot screen then your card might be dead.
Apr 28, 2007 | ATI Radeon 9600 Pro 256MB DVI+CRT+TV 8X...
Samsung SyncMaster 550S Monitor Logo
413 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
