Question about Samsung SGH-d807 Cellular Phone
Freezing screen i plugged my usb cord into my samsung sgh-d807 about 30 seconds after i took it out it turned off and whenever i try to start it again the screen freezes and flashes approx every 20 seconds . WHAT DO I DO , i have only had the phone for 3 months .
  • 1 more comment
  • Anonymous Jan 22, 2008
    i turned off my samsung sgh-d807 and plugged in the charger, then a few mins later i turned it back on and it froze i took out the battery for a few mins and put it back in and it turned on but didnt unfreeze i left it on and a few mins later it shut off and now it wont turned back on i just got a new battery for it today and it was working perfect. how do i fix it??
  • seanyboyy May 18, 2008
    Phone is freezing every time i put in a memory card. flashes every 10 seconds on a blue and white screen saying Sgh D807. and below that Samsung
  • Acacio Nov 05, 2008
    When I turn on my phone the screen would freeze when the SGH D807 name shows up and it would turn off by it self but now it does not turn on at all.
I turned off my samsung sgh-d807 and plugged in the charger, then a few mins later i turned it back on and it froze i took out the battery for a few mins and put it back in and it turned on but didnt unfreeze i left it on and a few mins later it shut off and now it wont turned back on i just got a new battery for it today and it was working perfect. how do i fix it??
Posted on Jan 22, 2008
  • 2,042 Answers
Remove the battery for few minute if it still dont work look in the manuel how to reset normally they put it in the back small push it with a pen hope it work cheers
Posted on Jan 19, 2008
6ya staff
SOURCE:
I have a toshiba satellite x205-s9349. It won't boot at all, no beep codes or screen. The fans start and the hard drive lights go on for a bout 4 seconds and then the fans turn off and nothing....
Try this
unplug plug the power cord and remove the battery and hold the power button for 45 seconds,Then reinstall the battery and and try to start the computer,
if it fails to start
unplug plug the power cord and remove the battery and hold the power button for 45 seconds and
remove the memory and any usb devices that may be plugged in,then start it,
If it starts
Allow it to load completely and then shut it down and install one memory stick and restart, if all is well after if loads completely, shut down again and install the other memory stick and restart, if all is well again wait until it loads completely and then plug in and allow to load each of the usb devices you may have
Jun 29, 2011 | Toshiba Satellite X205-S9349 Notebook
Whenever i try to turn my Samsung Gravity off, to seconds later it turns itself back on again. How do I fix this?
Take out battery for 30 min. Or you can leave the battery to be emptied and phone will switch itself. Don't turn on just plug in charger.
Sep 20, 2009 | Samsung Gravity SGH-T459 Cell Phone
USB Cord (Sam D800) works fine w/ phone, but computer freaks out
scan for viruses the setup might be corrupted try for a new version or compatible software
Jun 28, 2009 | Samsung D800 Cellular Phone
Samsung 3g mobile software poblem
The display on my samsung SGH-L768 is not working
Mar 30, 2009 | Samsung Cell Phones
Walkman will not charge
Whenever I plug my Walkman into my USB hub, which is connected to my desktop, it too says it's battery is full after just a few seconds. I plugged it directly into my laptop, and it took a charge as normal. Then I plugged it into a different USB port on my desktop, and it again took a charge as normal.
So, if you are using a USB hub, try plugging the Walkman directly into one of the computers USB ports, you may have better luck.
Mar 26, 2009 | Sony NWZ-E438F Digital Media Player
USB Cord
try changing the USB cord to avoid purchasing one, bring your camera to your retailer and ask them if you can try to charge it there, if it does you have to purchase a new USB cable through myaccessorymall.com if the camera is still in warranty, you can try to call samsung and ask them for a new USB cable
Mar 19, 2009 | Samsung L200 Digital Camera
Samsung E900
if the card came with an adapter, then plug it into your computer using a key drive that can take SD cards, an adapter that you can plug in a USB port, or by plugging it directly into the computer (most desktops can do this now). Then go to the card in My Computer, right click on it. and hit properties. A window will pop up. look for a tab called tools, then look for an option called error checking. Run this. If this does not clear up the problem then go back to my computer, right click on the card again, then click "Format...". A Window will pop, up. leave all boxes unchecked and start the format. when its done, it SHOULD fix ur problem. if not then i have no clue.
May 13, 2008 | Samsung SGH-E900 Cellular Phone
Samsung d900i
what they should do is give you a new mobile or reflash the mobile for you
Mar 30, 2008 | Samsung SGH-D900 Cellular Phone
Sansa seems to be frozen at startup
is my sansa broke or wat. when i plug the usb cord in the sansa comes on and wen i take it out it goes off , but the screen don't come on......i suffered the problem of wen the screen do come on it stops at the sansa rhapsody part then start over back to the big sansa screen then sansa rhapsody..........someone please help!!!!!!!!!!!!!!!!!!!!!!!
Sep 11, 2007 | SanDisk Sansa e250 MP3 Player
Samsung SGH-d807 Cellular Phone Logo
315 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
