Question about HP Compaq nc6220 Notebook
Touchpad I am experiencing issues with the touchpad on several of our nc6220 and nc6230 laptops, the touchpad just locks up. The only way to unlock the bad that I am aware of is to restart windows. Any suggestions as to how I fix this issue?
  • leightonthom Jul 23, 2008
    i hav a problem. the eldest lad has some how locked tho touchpad on his toshiba equium a60 laptop. does anyone have a solution for me please?
    Problem Solver:
  • 4 Answers
Reload drivers for touchpad.
Posted on Jan 19, 2008
Unlock gateway touchpad
some touchpads have button for that....
some touchpads have lock pattern to lock touchpad.... and also to unlock it
if you have a mouse plugged in then unplug it then restart your comp
then after restart you can plug in mouse back again
Feb 12, 2014 | Computers & Internet
Keyboard unlock
Like most modern laptops, IBM/Lenovo laptops feature a built-in touchpad that you can use as a substitute for an external mouse device. If you experience a non-functional or "locked" touchpad, then you have one of two possible problems; either the touchpad's drivers are corrupt or a user has manually locked the touchpad. In either case, you can unlock your touchpad and restore it to functionality quickly.
Open your web browser and paste the following URL in the address bar:
Click the "Download" button and then click "I agree" to save the Lenovo touchpad driver installation file to your computer. Double-click the EXE file that you downloaded. Doing so opens the driver's installation wizard. Follow the on-screen prompts to re-install your Lenovo's touchpad drivers. If your locked touchpad is due to a corrupt or outdated device driver, then your touchpad is now unlocked and functional. Activate Touchpad Hold the Windows logo key and press the R key to open a run command box. Type "control mouse" in the box and press Enter. The Mouse Properties control panel window opens. Click the "Device Settings" tab. Click the Lenovo Touchpad in the "Devices" list and click the "Enable" button to activate the Touchpad. Click the "OK" button to save your changes. Your Lenovo's touchpad is unlocked and ready for use. Lenovo support
Feb 24, 2013 | Lenovo Computers & Internet
Touchpad as stopped working
Are you sure you did not lock the touchpad?
Some laptops will have a button at the top of the touchpad in the middle that locks or unlocks the touchpad.
Some laptops provide a feature where you have to tap twice in the upper left hand corner of the touch pad to lock or unlock it.
Some laptops will require a keystroke to lock or unlock the touchpad. Normally you will have to Press and Hold the ALT or FN function key at the lower left portion of the keyboard then hit the key that toggles the touchpad. The correct key to hit will have the icon of a finger pointing at a square which represents the touchpad.
Download and reinstall the drivers.
Get onlineand got to In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Apr 25, 2012 | Acer Computers & Internet
Running W7 on an Acer Aspire laptop and the double tap to select function doesn't work. I have to right click and open to select or open a page or folder. i tried everything on the Elan mouse...
You do not identify your laptop model.
Try toggling the central button which on some laptops locks un unlock the touchpad/mouse controls.
If this is not the problem, reinstall the touchpad drivers from the driver CD or downloaded from the Acer website to clear any possible corruption. > support > driver downloads
If this does not solve the problem there may be a hardware fault with the touchpad.
An experienced technician would have to open the laptop and lift the chasis cover to isolate the touchpad and check for a loose cable, liquid spillage damage or component failure.
A replacement touchpad itself will not be expensive and the cost of repair should not be prohibitive.
If the fault is in the motherboard contorller/connector of the touchpad, then repair (replacing the motherboard) may be uneconomical.
a USB mouse will work just fine on a laptop.
I hope this helps.
Aug 25, 2011 | Computers & Internet
I am loking for touchpad drivers of Lenovo laptop Model- 3000 G430
Hi appoddar1988,
I see you need drivers for your Lenovo G430.
what type of drivers do you need? you mentioned that you need touchpad Drivers, what issue are you experiencing with you Touchpad?
You can get the drivers from this link .
But if you are experiencing Jumping cursor issue then you do not need to reinstall your touchpad drivers you try installing touch freeze on your system this actually helps with the jumping cursor issues in th Lenovo G series Laptop.
Just google Touch Freeze you should see links where you can download Touch freeze for free.
I hope this helps.
Have a nice day,
Jun 15, 2011 | Lenovo 3000 G430 Laptop Charger...
How to unlock touchpad of hp probook 4520s laptop
Touchpad zone is on upper left of the touchpad:
Turning the TouchPad on and off
The TouchPad is turned on at the factory. When the TouchPad zone is active, the light is off.
To turn the TouchPad on and off, quickly double-tap the TouchPad off indicator.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 02, 2010 | HEWLETT-PACKARD ProBook 4520s
Im using the hp mini 210-1000 laptop and ive accidentally lock the touchpad. Now i dont know how to unlock it back. Pleaseeee help me
just double tap the left top corner of the touchpad on your mini. the red light will go away and the touchpad is active now. repeat the same to lock and unlock the touchpad.
May 18, 2010 | Computers & Internet
I am having HP laptop. For last 2 days my touchpad
try reinstalling the driver for the mouse pad
that should go fine
Jan 05, 2010 | HP Compaq nc6220 Notebook
How to remove the nc6220 touchpad lock the side please be careful you only go left and upward..good luck and hopefully help me have you..
Jul 20, 2009 | Computers & Internet
Synaptics touchpad mouse will not move cursor
Update synaptics driver from that should fix the issue
May 16, 2009 | HP Compaq nc6220 Notebook
HP Compaq nc6220 Notebook Logo
540 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
