Question about Vacuums
Loose Wand Connection
I have a Kenmore Progressive Canister Vac #21612. The metal wand, right at the point where it plugs into the powerhead, does not make a solid contact, it has about 1/4 to 1/2 inch of play in and out. Because of this it does not make constant electrical contact. Sometimes the wand comes out completely. I'm not sure if the problem is with the wand or with the plastic piece that is part of the powerhead. Any suggestions? Charles
  • 397 Answers
Its just worn, sometimes getting a new lower wand can fix this
Posted on Jan 20, 2008
My kenmore progressive canister vacuum turns on only if the hose is attached to the floorwand. It seems that the canister motor is not working because I can't hear anything coming from the caniste
If the floor wand is powered, there may be an electrical connection that is broken when the wand is disconnected. This is part of the design, not necessarily a fault
Jan 05, 2013 | Vacuums
It stopped working while I was using it . I tried to plugged in different electric outlets but it still dead. What should I do or look into in order to get it back to normal?? thanks
I would start by taking the wand apart. Be sure vac is unplugged from the wall outlet! You should be left with two pipe pieces, and the beater bar. I would also pull the hose from the canister unit itself. Once all the pieces are pulled apart, check the two or three prong wire connectors on each piece, both the female and male ends. If you have any dielectric grease, use a dab on each electrical connection. Once you reassemble, and still not powering up, wiggle the wand back and forth at the connection near the canister, and after the hose near where the switch is. If the vac cuts on after wiggling it, then you have a loose connection, and will need to tighten the female ends on the electrical connections, by squeezing them together slightly with a pair of pliers. Please rate if this works or does not work. Thanks!
Jan 03, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
The powerhead on our kenmore progressive canister vac (model 116.25615506) turns on and off as the yolk handle is raised and lowered. what is the most likely cause and is it repairable? thanks,
Wires (pins) are burned in the handle connection, usually the top section by the switch, unhook from the metal wand and inspect the connection, look for black sooty looking pin holes or pins, check both sides. This means the pins have burned slightly and now have a loose connection with little or no continuity. Very common, you will need to repair with a wire Kit or have a professional do it. Horrible design flaw been going on for years with these types of vacuums.....ACE
Dec 15, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore 25614/25615 Progressive bagged canister vac won't start
sounds like there was a loose connection or loose wire that came in contact with another wire. check your cord for small burn holes, also could have shorted out in the hose or the wand. If you are comfortable to disassemble the vacuum i can walk you through the troubleshooting process so we can find out what actually went bad. id start with the cord though. let me know if you have any questions or need more assistance
Jan 04, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
We have a Kenmore canister vacuum cleaner. the carpet cleaning attachment, I think is called the power mate has a beater that is intermittently working now
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
Jan 03, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
Loose electrical contact in extension wand
You have a loose connection at one of several possible locations.Inspect the contacts at the top and bottom of the wand .IF they are black or coppery or look melted, both pairs of contacts, male and female will need to be replaced.
Try to wiggle and twist the wand at top, then at bottom. If this does not reveal the short, work your way back down the hose towards the a vac itself, starting behind the hose handle.
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Carpet attachment
Check the plug ends at the top of the wand and the plug going into the hose handle, also at the bottom of the wand. It sounds like they may be burnt, if so they will need to be replaced. One cause of these connections going bad is not turning the power head off when connecting or disconnecting. Therre are other causes, the switch in the handle is going bad, also some of these cannisters have a relay mounted by the vac motor, sometimes they go bad.
Mar 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Powermate connection flickers
I had the same problem. Sears has replacement parts for mine (Model 11625813506) here: http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=11625813506&pop=flush
Rather than pay $10 for a new cover terminal (which I probably couldn't install myself anyway), $99 for a whole new wand, and possibly $108 for a whole new hose (ridiculous prices, btw), I took a small flat head screwdriver and scraped off the dirt/corrosion on the terminal pins. This didn't resolve my problem, but I noticed the connection between the extension wand and the "Power mate" hose handle was loose. The handle could wiggle/slide about 1/8" when connected to the wand, creating the loose connection. I used the screwdriver to bend the pins down slightly (in the direction away from the wand tube), to compensate for the loose connection. This worked like a charm, fixed the intermittent circuit contact completely, and was very easy to do. I'd highly recommend trying this, before doing anything more complicated.
Feb 09, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Jan 11, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
223 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
