Question about iLO 3200 32 in. LCD Television
Remote code numbers .
I have a oneforall remote i need the codes for the TV listed below.
    Problem Solver:
  • 10 Answers
Re: remote code numbers .
Check to see if your universal remote has an autosearch or manual search function. This allows you to repeatedly press one or more buttons until the unit turns off and then you have found your code. If you no longer have the documentation for your remote you may be able to download it online.
Posted on Jan 18, 2008
0 characters
3 Points
Tv code for all for one remote urc4021b00 for sanyo tv
Many One For All remote manual and code lists are available here: . Use the drop down menus to select universal remote control and then the specific model. You may need to change the country (at the top) to find your remote.
Try the code 0154 for a Sanyo TV. Please note that most universal remotes only have the codes for devices released 6 months or more before the remote was programmed. If your remote is older than your TV, you may need a newer TV.
The direct link to the manual for the URC4021 is . The URC4021 manual has a copyright date of 2004 but may be newer than that (07/08 footnote).
I hope this helps.
Sep 24, 2011 | Flat Panel Televisions
One for all remote control will not work? Do I need a special code?
Hi Zee,
If you go to the oneforall website - you can enter the model number of your remote. It is either printed on front of remote under the oneforall symbol or in the battery compartment at the rear.
Then you can enter the make and model of the device you're trying to use it on, TV, DVD, etc. (TV Model Number is usually on a label at rear of tv) It will give you a code to input into the remote. It gives you instructions on how to do that underneath the code.
Hope that works for you. I have found them to be pretty good for tv's, freesat boxes etc.
Regards, Tom.
Apr 23, 2011 | Flat Panel Televisions
Can you help me find the codes for a oneforall remote control. The model number is URC 3220
The code list is available at the One For All support site: . The link for the codes is at the bottom on the right hand side; a link to the PDF of the manual is on the left (this link seems to be broken). There is also an advanced search link,, that will let you enter the remote and the device and get the codes for that brand/device.
Please note that the codes in the remote are limited to those devices released 6 months or more before the remote was programmed. You may need a newer remote if the device you are adding to your unversal remote is new.
I hope this helps.
Feb 06, 2011 | Flat Panel Televisions
I have a remote that i need the codes for a oneforall urc3220 for a zenith tv
You can get the manual and the codes for the remote on the link below.
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 10, 2010 | Flat Panel Televisions
I have a oneforall access4 remote i need the code
enter 320 into the remote
please rate our helpo keep this service online
Aug 20, 2009 | Sansui 19 in. LCD TV
Lost code list and instructions
Codes -
TV Quasar 0051 0250 0650
Magnavox 0503 0675
If those don't work for you then go to this link -
At the bottom in tiny print is 'get codes' and that link will open-up a new window with all the codes listed.
May 22, 2009 | Westinghouse SK-32H240S Television
iLO 3200 32 in. LCD Television Logo
49 people viewed this question
Top iLO Flat Panel Televisions Experts
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Flat Panel Television Expert? Answer questions, earn points and help others
