Question about Turboair TAS-24H Split System Air Conditioner
Need a wiring schematic
Getting an E7 error message. cooling works fine but now heat.
  • pospime Jan 18, 2008
    need a wiring schematic for a Turbo Air split unit TAS 24h
D64e477
Posted on Jan 20, 2008
  • odyson Jan 12, 2011
    The 5vdc control wire between the unit inside and outside is not hooked up or control board inside is bad. Check the cable first. This is your defrost wire. You won't notice anything wrong till it drops below freezing.
I have Frigidaire 2.5 ton split Ac showing E7
According to frigid aired error code table it is regarding a Mode Conflict Error, but without your exact model number, I can't clarify this any further except to say that you have one of the heads in heating mode & the other head is in cooling mode which creates the mode conflict squalling the E7 Error Code, I do hope this helps... But please comment further if I can assist you in any way I will happily do so....
Mar 01, 2018 | Frigidaire Heating & Cooling
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems
Jul 29, 2016 | Sharp Ar 5316
E7 message
A/C Blowing circuit breaker and giving a error code E7 - Heartland ...
https://www.heartlandowners.org/.../24381-A-C-Blowing-circuit-breaker...
May 21, 2011 - 10 posts - ‎4 authors
Has anyone have any idea what could cause this issue? It is a Dometic rear AC with HP and will not cool at all. The fan runs but no cooling at ... Dometic Refrigerator - Error code E-3 - On the road, help ...
Jun 6, 2015
Dometic CCC 2 Error Code E7
Aug 9, 2014
Dometic A/C won't turn on with remote or from unit
Aug 30, 2012
More results from www.heartlandowners.org
Dec 02, 2015 | Heating & Cooling
Code error E7
I'm not sure if NewAir is made by Gree -- they supply many. On Gree units, E7 simply means one unit is requesting heating while another is requesting cooling and you can't have both at the same time. So that's the first thing to check. Very simple, very common, doesn't indicate that anything is wrong with the system.
Apr 05, 2014 | NewAir ACS-1200H Split System Air...
Airlux error codes E7
This is probably a "mode conflict" where one of your units is trying to heat while one is trying to cool. You should switch one of those to fan instead or have them both on heat or both on cool.
Jul 09, 2013 | Heating & Cooling
Dometic roof top Error code E7
bad temp sensor but could also be control board
Jun 27, 2012 | Dometic Rooftop RV Air Conditioner
E 7 error code is displayed on my SportsArt 1210 treadmill. When keep it turned off for a long time, then the machine works fine but if I switch if off and back on again, E 7 is displayed and nothing...
i have the same treadmill with an error 10 message. i have the booklet that came with it and it says that an error 7 message indicates(too much to write). I can fax the error message page and the wiring schematic to you. my email is srt8ght1999@yaho.com. not posting my number here.
Jan 05, 2011 | Exercise & Fitness
Haier air conditioner show E7 error and does not work
same problem because of voltage problem . here voltage was 400 so it was show e 7 then i made my voltage normal and ac is working good (y)
Jul 07, 2010 | Heating & Cooling
I have an 18 K unit with E7 error on heat mode
I just installed a YMGI brand mini-split AC and had exactly the same problem. AC worked fine, but when I tried using heat mode I would get an E7 error.
After talking to their tech support I discovered the problem. There was a separate cable that needed to be connected that I'd forgotten to hook up. This cable runs from the internal unit to the outdoor unit and connects a defrost sensor.
In my case I had totally missed that cable when I installed the unit. After running another line and connecting it the unit is now functioning normally.
If this is a new install, then make sure all your cables have been run. If it was previously working, then check to see if one of the cables had become disconnected. If it's not the cable, then it's probably the sensor.
Good luck
Oct 18, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
Turboair TAS-24H Split System Air Conditioner Logo
379 people viewed this question
Top Turboair Heating & Cooling Experts
Steve F
Darial Jr Lasaria
Darial Jr Lasaria
Thomas Woodburn
Thomas Woodburn
Are you a Turboair Heating and Cooling Expert? Answer questions, earn points and help others
