Question about Intermec T1700 Portable Terminal
T1700 Charger I need a multi station NIMH battery charger for the T1700 scanner
0 characters
1 Points
How do I replace document feeder,broken?
You state that this "was new out of box" the machine. If this is so and particularly if the machine is new then you should take it back to the vendor for him to replace with a working unit, because clearly the one you have is "not of Merchantable Quality".
Hope this is helpful, if so would you please register that with Fixya
Jan 26, 2015 | PANDIGITAL Handheld Wand Scanner Wfeeder...
What kind of fuse do I need for the symbol 4 slot battery charger
The UBC 2000 Fuse part number: 217005 (5A 250v Quick Blow), orderable from Little Fuse (Phone: 847-824-1188).
Apr 27, 2014 | Symbol 4 Slot 4 Sled Universal Battery...
Dell studio 1555 laptop will not reconize charger, charger and battery were checked on another laptop and are fine.
Thats a hardware issue of your laptop. You'll need to take it to a service centre to fix it, hope you still have your warranty left.
May 12, 2011 | Barcode Scanners
Please describe your nokia1100 plugein charger but no risponse charging problem:
Check your charger with another phone and if the fault is the same the charger is faulty as there can be poor regulation within the charger. you will need to cut open check the capacitors or the rectifier and measure the voltage. If not change the adapter.
However if the charger is good the fault can be the battery or the phone circuit. ReCheck the battery to confirm
Feb 09, 2011 | Barcode Scanners
With another laptop all chargers seem to work but on mine its own charger does not work yet the other charger works excelently
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Dec 31, 2010 | Barcode Scanners
My charger has been plugged in but the battery is not charging. i have an acer aspire 5740 laptop
me too the same... When I plugged in the charger the power indicator shows battery in charged 100% when I removes it goes to 0%.. I installed ubuntu on acer 5740..
Aug 31, 2010 | Barcode Scanners
Wifi switching off automatically in mc9090
plug a car charger or mains charger into it and get power back to it before the battery gets low :D
Apr 18, 2009 | Zebra Symbol Technologies MC909X-G Series...
Intermec T1700 Portable Terminal Logo
Top Intermec Barcode Scanners Experts
Brian Sullivan
Brian Sullivan
Are you an Intermec Barcode Scanner Expert? Answer questions, earn points and help others
