Question about Performance Teknique ICBM-782 Car Audio Amplifier
My battery dead when i want to turn on car--what do i need?????
Can someone help me please i got 2 amps hooked up a 1800 watts performance teknique and a 600 watt koiiler amp ever since i installed the 2nd amp my battery gets dead very easy and friends tell me i need a capacitor n other said i need monster cables but i want to know what i really need to buy can someone tell me what i need pleaseeeee!!!!!!!
  • 2,039 Answers
Monster cable its good for our amp but do nothing for the battery its all depend how many amp our amp take away from the battery if our alternator is 90 amp maximum the alternator output is 75% off 90 amp =70 amp available if each amp take 25 amp you only have 20 amp left for everything else there no way our alternator is enough that y you drain the battery you need a bigger alternator and battery the minimum you can do is put ourself another battery you gonna have more capacite but you gonna have to charge it up at night put a little battery charger 2 or 3 amp per hour that should fix it cheaply hope it help dont forget to rate me cheers
Posted on Jan 18, 2008
I have 2 kicker cvr 15 4ohm dvcs and a performance teknique ICBM power 4000 watt 1ohm stable amp when I hook up my speakers 1 ohm it kicks my amp into protect when I wire it at 4 ohms it works fine how do...
Are your subwoofers wired in series or parallel? Check your connections, if everything is ok, the problem is with your amplifier. It might have a blown capacitor inside or its not really a 1ohm stable amplifier. Have it repaired if thats the case.
Apr 11, 2011 | Performance Teknique Car Audio & Video
No problem just need advice
if you use for bass need to adjust to a 120Hz in the amp & eq
Apr 26, 2010 | Performance Teknique ICBM-772 Car Audio...
I Hooked up a Performance Teknique 1200 watt 2 channel amp to my 2 12" comp kickers. and before doing all this i took out the fuse. from my car battery. after everything was hooked up i put the fuse back...
disconnect the amp and then put the fuse in.if it blows,there is a pinched wire causing a short.
Also,big amplifiers like that have to be wired battery direct.
the surge current at boot up can pull 100 amps for 10 millisec.
Jan 13, 2010 | Performance Teknique ICBM-892 Car Audio...
I have 2 perfomance teknique 700wts and i dont know what kind of amplifier use
Hello perezmagdiel,
That 700 watts is maximum peak power, not RMS. If you're looking to not spend a lot of money for an amp, but want something that sends enough power to the Performance Teknique's, I'd recommend a 2-channel like the Boss Diablo D400.2. It's plently powerful enough and if you change out later, the amp can be bridged. And for inexpensive, it's got a lot of nice features, including a remote level control. It's 2ohm stable in stereo. Nice, for under $70.
Hope this helps.
Jul 17, 2009 | Performance Teknique ICBM-892 Car Audio...
I Have 2 12inch jl audio subs and 1 800 watt kenwood amp and its just not enough boom, so was thinking about installing another amp (performance teknique ) but not sure how to wire it all up......n e help...
How is it wired now? One amp with individual wire to the two subs in stereo mode? What are your plans? Are you adding a matching amp or just buying a larger one to replace the one you have?
Jul 12, 2009 | Sony XM-SD61X Car Audio Amplifier
Performance teknique icbm 892 1200 watt amp
DD, JL and pioneer in that order. I don't recommend any particular size but 12s are a good compromise.
Sep 21, 2008 | Performance Teknique ICBM-892 Car Audio...
Audio system set up
Well one problem is you might need a smaller amp depending on how many speakers you have, 1200 watts is way overpowering for 300watt max speakers and could possibly blow them and even catch them on fire!!!! But everything else is compatable because all of your epuipment is of a newer products but if you dont have 4 guage wires or anything else make sure you get them heres a list: 4 gauge wires for power and ground, REM wire "blue is the normal color" RCA jacks, A compacitor, fuse for battery to amp to keep system from blowing up, 8 gauge speaker wire or even 12 guage to hook up from the amp to the speakers, That should be the common things you need to have a good thumpin system!!!!
Sep 12, 2008 | Performance Teknique ICBM-892 Car Audio...
Performance Teknique ICBM-9550 Amp Problem.
one of the power transistor of your unit shorted check use a tester
Aug 27, 2007 | Performance Teknique ICBM-782 Car Audio...
Performance Teknique ICBM-782 Car Audio Amplifier Logo
128 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
