Question about LaCie d2 DVD-RW Burner
Low power problem?
When I turn on the dvd writer, I get a green blinking light.  I got one error message that the drive couldn't work because of low power.  Could this be the adaptor?
    President:
  • 1,944 Answers
There is a good chance that the problem is with the power adapter. I would suggest checking the connections and the adapter itself and the wires to make sure nothing is visibily damaged. I would also try connecting to another outlet.
Posted on Jan 18, 2008
  • 1 more comment
  • Damen Wong
    Damen Wong Jan 18, 2008
    Has the unit or adapter suffered any physical damage?
  • Damen Wong
    I would also try disconnecting the drive from everything (computer and power) and leaving it disconnected from everything overnight. Then reconnect and see if it works.
  • Damen Wong
    If it interests you then here is the support site for your drive
    http://www.lacie.com/support/support_man...
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
When i put some dvd disk in the drive it does not read but the light in the front just blinks constantly
Is your DVD-writer not recognizing any disk? If it so, the most probable case is that your DVD-writer's Optical Lens has been corrupted. Go for another new DVD-writer or try repairing your DVD-writer.
Dec 24, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Blinking red light.Checked all cables. I replaced Hard drive...still problem exists. Wondering if power supply could be problem
When one light from the four lights ring itself changes from green to red, it means that a general hardware failure has occurred or is imminent. Blinking of one red light with an error message like E66, E67, E68, E71, E74 or E77 means a repairable problem while the one red light blinking without error message means some critical or irrepairable problem. The problem can be avoided by restarting the Xbox 360 console but if you have not received any error message with one blinking red light then the problem is irrepairable. The console will behave the same way and you should understand that one or more of the hardware components in your console have stopped functioning due to hardware failure. If you receive an error message with one red light blinking then the problem is reparable and the system will definitely start working. It means that there is some hardware problem with the Xbox 360 console connection occurring due to the misplacing of cables in the ports. Turn off your Xbox 360 and disconnect all cables, now reconnect the cables and switch on the Xbox hope this helps.
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
MY HP 840i dvd-rw can read CD but can't read DVD
if you have cd writer and dvd rom then change your cd drive with cd/dvd writer because in the case of cd writer and dvd rom it gives error but sometimes the dvd play also but computer freeze from sometime and when we copy data then give us error messages i give you suggest to buy new cd/dvd writer
Jun 29, 2009 | HP Computers & Internet
Write error message with liteon dvd writer..
I had the same issue with a liteon DVD drive I had. It worked fine and then one day it couldn't write to a DVD if I paid it to. I troubleshooted it for a few days, installed all the latest updates and patches and still nothing. From what I could tell, it baiscally died. So fortunately Liteons are relatively cheap so I just went out and got another LiteOn and it worked just fine. I would consider purchasing a new Drive.
May 04, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
DVD Writer not working
Make sure the jumper on the back of the new drive is set the same as the old one. EXAMPLE: Slave, Master, Cable Select
Jun 13, 2008 | Computers & Internet
Compaq presario dvd writer light blinking, dvd not working
check if power jack working right. Try to change it with other jack. Sometimes the pins inside jack are loose. try to tight them.
May 12, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
DVD writer not reading disks
change ide cable 1st ok get back with me thx nick
Feb 03, 2008 | Computers & Internet
LaCie d2 DVD-RW Burner Logo
94 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
