Question about Cornea CT 1700 17" Flat Panel LCD Monitor
No sound coming from speakers.
Apparently this monitor has built in speakers, however I turned the volume to the max under the monitor itself's menu and change the system volume to max + set it to monitor speakers. still nothin. any tips?
  • kyerra Jul 12, 2008
    i cant get any sound from my speakers
  • 38 Answers
Did you run the audio cable from the computer to the monitor. If not you must have that for the speakers to work. If yes can you verify computer output with another pair of speakers to narrow it down to computer or monitor. If it is the monitor built in speakers that are the problem reply and we can go through a procedure to get them working.
Posted on Jan 18, 2008
Sound from built in speakers
There will either be a menu driven volume control or physical volume buttons. Also make sure you have an audio cable plugged in from the monitor to the computer. It will typically be a lime green port on both. Connected by a 3.5mm head phone jack
Feb 02, 2013 | Envision 19" Widescreen Flat Panel LCD...
Aoc 2436VW monitor SOUND DOES NOT COME ON
Most monitors with speakers built in need a 3.5 audio cable with jack on both ends,very inexpensive cable, that you connect from the audio port on monitor to the audio out on your sound card. You may have to go into the menu on your monitor and turn the volume up or make proper adjustments...
Dec 27, 2012 | AOC Computers & Internet
My computer is a SyncMasterP2570HD i cant get any sound to come out but it is detecting sound how do i fix it
The Samsung SyncMaster P2570hd is a monitor with speakers; it isn't the computer itself. I'll assume that you are dealing with a computer connected to the monitor and not a set-top box. Make sure that Mute is not enabled on the computer. There should be an icon on the lower right hand side of a Windows desktop. If the mute is enabled, it will have a red circle with a diagonal line through it. Left click on the icon to remove the mute (change the volume or click on the mute icon). Test the monitor's speakers by connecting it to another device with known good audio output.
Next how are you connecting the monitor to the computer (VGA, DVI or HDMI)? If you are using VGA or DVI (including DVI to HDMI), you need to connect an audio patch cable (3.5 mm) between the speaker (green port on the back of a sound card) or headphone jack of the computer and the audio input jack of the monitor. The audio input jack is between the DVI and VGA ports. You can test the output of the speaker jack on the computer with regular computer speakers. Plug in the power cord (or USB cable) for powered speakers. If the free-standing speakers work, check the volume setting on the monitor with the +/- buttons to the right of the menu button. Do not press menu first, though. If that doesn't solve the problem, continue using the separate speakers. (Unless the monitor is still under warranty, it usually isn't worth taking apart a monitor to replace the speakers. You may be able find replacement parts online.)
If you are using an HDMI cable, check the output audio setting to see if the HDMI audio is available. For Windows, click on Start > Control Panel > Hardware and Sound (Windows 7). Then click on Manage Audio Devices under Sound. In the Playback tab, check what available audio devices you have. Make the HDMI the default device by right-clicking on it and selecting Make this the default device. (Other versions of Windows will a slightly different route to this panel.) You may need to restart the computer to get the audio signal on the HDMI cable after setting this. Note: not all video cards/computers support HDMI audio. If you don't see HDMI listed in the Playback devices, connect an audio patch cable as with a VGA or DVI cable, described above. Use stand-alone speakers if the monitor's speakers are bad.
I hope this helps.
(I have had the speakers fail in monitors; <$30 separate speakers are an adequate replacement for those built into a flat panel monitor.)
Jun 26, 2012 | Audio Players & Recorders
How do i turn off the sound
You can use the function button in your keyboard + Mute sound button in the top keyboard rows to mute and unmute the sounds.
(fn key + Mute symbol key)
I hope this is helpful to you.
Thanks
Apr 26, 2010 | Dell Inspiron 2200 Notebook
Need more volume on computer speakers
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
Oct 02, 2009 | ViewSonic VX910 19" LCD Monitor
Cannot raise the volume
Speakers built in to monitors are notorious for being quiet. But, check the sound in control panel and see if it knows you r useing that type of speakers. And of course check monitor itself for a manual volume control.
Jun 24, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Very Poor Sound level on ASUS VW223T monitor
check to make sure you have the proper drivers for the monitor.
May 18, 2009 | ASUS VW223T 22in 16:10 5ms LCD Monitor...
Cannot get any sound from my Dimension 3100
Speakers are not built into the box itself. They may be in the monitor, or completely separate.
Did you get this directly from Dell, or from a third party. Dell would have shipped you speakers with it, or a monitor with speakers built-in. Purchased from a third-party you might just get the box itself.
If you have a monitor with speakers, you still have to connect the sound output from the box to the monitor.
Mar 05, 2008 | Dell Dimension 3100 PC Desktop
No speaker volume
Hey Mate, being honest weve sold alot of TFT monitors and most are hard to hear with all the volumes turned up, only thing you can try are. turn volume up to max on the monitors menu, also double click on the little speaker icon on the bottom right hand corner of the screen and a volume menu appears turn up WAV, & the main one on the left. if you are not getting any sound at all check you have the audio cable from the monitor plugged into the green connection on the back of the pc. Afraid thats the only options to get it louder or buy a set of speakers to get the sound louder. All the best John
Mar 03, 2007 | Daewoo F227B Monitor
Cornea CT 1700 17" Flat Panel LCD Monitor Logo
370 people viewed this question
Top Cornea Computers & Internet Experts
giarcnameloc
Level 1 Expert
Tom Chichester
Are you a Cornea Computer and Internet Expert? Answer questions, earn points and help others
