Question about Samsung SCH-u740 Cellular Phone
I can't get my cell to turn back on
I've had it charging for days now and i can't actually get it to turn on. When its charging its all lit up and running but the moment i take the charger out its dead and won't turn on how do I get it to turn on ?
    Brigadier General:
  • 7,752 Answers
Try changing the battery first, if that does not fix the problem......them take the phone to a mobile service center and have then reflash the firmware.
Posted on Jan 18, 2008
The main screen on my Casio G'zOne Ravine (C751)
Let it charge for 24 hours before trying again. Battery may be too weak to light up the display yet.
Sep 24, 2013 | Cell Phones
I have VIBE bluetooth keyboard for iPad mini ( VE 1089) and can't find ON switch
yes the red charge light will only stay lit for just a little bit... then turn it on by pressing down above the words written "charge". You should be pressing and holding down on a dial with three semi circles above it (as szuravic stated). Press and hold down until you get the bluetooth and power button lit on blue. Then go to your settings and bluetooth.... "bluetooth keyboard" should pop up. Click on it and then it will ask you to enter a 4 digit code on your keyboard followed by the return key. Soon after you should be "connected". If you are fully charged (first time plugged in should be 12 hours.. then after 4 hours) then you can unplug. Hope that's helpful!!
Feb 05, 2013 | Apple Ipad I-pad
Trouble starting (on hot days?)- seems like a power issue, but battery and starter are OK.
You may be making this too complicated.
When the air temp is high, the battery can become weak. So a battery that tests "good' today may be "fair" when it is 90 degrees.
Heat and lack of water are the biggest killers of car batteries.
And a starter can take twice as much current to operate when hot than when cold. Dampness and humidity are also factors in electrical circuits.
I would disconnect the battery when the truck is going to be parked for more than a few hours until you find the problem. That way you will know nothing in the truck is draining it.
Also, you should have the output of the alternator checked. A failing alternator would not have anything to do with the check engine light on your truck. The alternator can be charging 5 amps which would be enough to knock out the battery light, but not enough to handle the heat and the load of running the ac. It should be able to charge 40 or 50amps at road speed when needed.
The check engine light and rough running stuff does not involve the starting system. Only the battery, starter, and cables.
Sep 16, 2012 | 1987 Toyota Pickup
My computer won't turn on
If you tried turning the laptop on with NO battery but plugged into the mains and you get no response, even no little lights flickering then its possible that something to do with the motherboard (obviously, you might think) but get someone too look inside it if you can, something might be fried.
its a bit hard not actually seeing the machine
May 09, 2012 | HP Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My i465 went dead and now it wont turn back on....when i plug it up to the charger it wont charge i put my friends battery in it (he has the same fone) and it still wont turn would i...
u better contact motorola for further could possibly a hardware problem that you can't fix, only the technicians of the manufacturer..however your phone actually has a warranty of 90 days from the day u bought it.. make sure of the warranty of your phone
Oct 02, 2010 | Motorola Mobility Clutch i465 Cell Phone
When I charge my iPod Nano it charges fine but instead of turning off or ... it will turn off but in about 2 seconds it goes to the "Charged"
I do NOT want to Pay for a solution ONLINE.....because after 12 hours of work on it, and internet feedback, I am SURE it is a Hardware GLITCH.....It has happened to I am Not sure ,,,,but probably will have to take to China's 1st apple store
Let me Know if HARDWARE or Other Glitch.....CHARGED remains when I turn it Off until VERY LOW Battery + Kills it
Aug 02, 2008 | Apple iPod nano
Phone keeps freezing
u need to do hard  reset of ur fone and pls take back up before that...or else there is problem with charging slots pins and turn on/off button,,,,,,,,
Sep 09, 2007 | Nokia N95 Cellular Phone
Nokia 9500 doesnot boot
hi for this problem == plz check this out hope you can get your cell back as it was! GOOD LUCK
Apr 28, 2007 | Nokia 9500 Communicator
Samsung SCH-u740 Cellular Phone Logo
57 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
