Question about AOC LM729 17" LCD Monitor
Monitor problem Monitor powers on and displays an image for 10-20 seconds then screen goes black but power light stays on.
  • Ladybuge Jan 19, 2008
    I kind of figured that was the problem but was not 100% sure. I'll get to work on it. Thanks a million.
  • 38 Answers
You are experiencing an inverter board failure. You will need to replace or repair the inverter. The inverter drives the CCFL lamps that illuminate the screen if the lamps draw to much current or components on the board are overheating it will shut down the backlights. Some monitors have cold solder joints on the toroidal coils of the inverter that causes this problem, very typical with HP monitors, If you are handy with a solder iron you may try just re-soldering board and replacing push-pull transistors for a few more years of use. Provide make and model and I can be more specific about probable cause and solution.
Posted on Jan 18, 2008
Its looks Bad CCFL lamps or a faulty TL1451 smd IC when power shutdown in 2 to 5 5 sec.
Imran khan
Posted on Jan 20, 2012
Desact monitor
When the following symptoms, that is, to replace a laptop LCD screen:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Jun 07, 2013 | Computers & Internet
Monitor black screen
To me this sounds like whats called "bad caps" problem. The capacitors in the PSU have gone out of tolerance and the back light is switching off. If this is the case you will need a workshop repair or if you know how to solder you could replace the capacitors in the PSU for the back light.
Jan 24, 2018 | Acer AL1917W LCD Monitor
2407 screen goes black
faulty connector... need to call a repair guy to solder a connection.. usually 50 bucks
Apr 20, 2012 | Dell UltraSharp 2407WFP 24" LCD Monitor
Monitor comes on but then shuts off in about a second
Try reducing the resolution (boot at safe mode)
Feb 22, 2010 | Dell UltraSharp 1908FP Monitor
The monitor comes on and then goes black.
Sounds like your LCD panel lamps are shutting down, this could be either due bad tubes, or more likely lamp driver power supply is faulty.
Jan 12, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
VA1930WM monitor turns on, displays normal for one second then goes black. Then it turns on again after a minute or so for one second and goes black. This keeps repeating over and over. Is there a known...
If it was the power supply, the light would change to amber (orange) and then turn green again when it comes back on. Look closely at the screen when the it looks to turn off. See if you can still see an image. It may be hard to see, but when the backlights go bad or fail, the actual lcd screen itself still functions and you can see a very faint image. Maybe moving the mouse in circles might help you to be ablt to see. If you cant see anything at all, then it may be a bad board inside the unit.
Just a thought....
Sep 18, 2009 | Computers & Internet
Screen goes black after 2 seconds
This could be one of two problems, the light in your monitor has a loose cable, or the light is dying. I have seen cold cathode lights that are about 10-15$ to buy and many instructions on putting them in yourself.
Solution 2, your cable is loose on the back of the monitor. Make sure you have the screws tightened on either side of the vga or dvi cable, both on the back of your monitor and on the back of your computer or laptop.
Jun 28, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Viewsonic VA702B
Monitor going black after a few seconds can be caused by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Jul 28, 2008 | ViewSonic VA702b 17" LCD Monitor
AOC LM729 17" LCD Monitor Logo
315 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
