Question about Cuisinart CBK-200 Bread Maker
Kneading paddle slips and won't knead
I've bought a new paddle, same problem. i've had this machine a little over 1 year. i think the whatever that turns the paddle in the motor is stripped. anyone else have this problem?
  • Anonymous Feb 05, 2008
    I had the same problem. Mine broke about 6 months after I bought it, so it was covered under warranty. Take it back to where you bought it from see if they'll honor the warranty.
  • angie_ca Jan 27, 2009
    My CBK-200 breadmaker is about a month old and has started doing this. The paddle slips off its shaft, gets buried in the loaf, and the loaf comes out very short and dense. If the paddle stays on the shaft, the bread turns out well. I suspect the short loaf is because the bread is not kneaded well enough to develop the gluten to support the rising.
SOURCE: missing kneading blade for reagl breadmaker
try ebay, there's some there!
Posted on Feb 07, 2008
  • 25 Answers
SOURCE: West Bend breadmaker 41030 needs knead bar
try here maybe measure your part then maybe a sub will work if someone can send you the specs.
Posted on Jul 24, 2008
  • 2992 Answers
SOURCE: I need a kneading paddle for TBR2!
A Google search turned up these folks. Looks like they have your paddle.
Posted on Nov 11, 2008
  • 63 Answers
SOURCE: Zojirushi breadmaker BBCC-S15 kneading paddle
You can purchase one here.
Posted on Jan 03, 2009
  • 247 Answers
SOURCE: Want to buy a kneading blade. Toastmaster bread maker 1171
Hi. You can get it here. Pls rate the answer
Posted on Apr 22, 2009
Kneading blade comes off during breadmaking process
Yes, if the blade come off then your bread is not going to mix and knead properly. The blades on all makers are designed to slip on and off though so you can remove them for cleaning etc. Be sure you are pushing the paddle all the way on. If it still comes off when mixing that would be very odd as the weight of the dough ball itself helps keep paddles on. I have owned dozens of machines by different manufacturers and never had a paddle come off in process.
Jan 01, 2013 | Sunbeam Oster CKSTBRTW20 Bread Maker -...
I have an old toastmaster bread machine model 1154, and I realized that the kneading blade does not rotate when the ingredients are in the bread pan. Either the kneading blade mounting shaft and the...
If the spindle is turning and the paddle is not then your paddle is worn out and probable slipping on the spindle. If the spindle isn't turning then your problem is underneath the pan or inside the drive and your paddle may be fine.
Dec 01, 2010 | Toastmaster Kitchen Appliances - Others
The part that the kneading paddle connects to in the machine is not working. Will not turn the kneading paddle
Hi, The sealed bearing that the paddle shaft fits through is frozen and has failed. You could try filling the pan 1/2 way with hot water for a few times to see if it turns but otherwise a new bread pan is needed. Hank
Nov 09, 2010 | Black & Decker Kitchen Appliances - Others
I bought my Cuisinart Bread Maker in February 2007 and it worked well until now. Yesterday I started to make Dough cycle. First 2 minutes machine kneaded the dough correctly as usual but suddenly...
check the underside of the basket. I have had problems with the lock washer, causing the wing nut to slip and not providing any turn to the shaft and paddle.
Sep 22, 2010 | Cuisinart CBK-200 Bread Maker
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
Only 1 Kneading Blade is working. The other stops
Hi, Could be the belt is slipping or is worn for that paddle. Belts and motor are located in the base of the machine. Hank
Mar 21, 2010 | Zojirushi BBCC-V20 Home Bakery Traditional...
Kneading blade stuck
The little bearing that turns the paddle is frozen. You will need to get a new bread pan. This happened to me after 7 years of use. If under warranty have them replace it. It was about $25.00 for a used bread pan on ebay, so I just bought a new machine at Wally World (Walmart) for $52.00.
Aug 03, 2009 | Sunbeam Kitchen Appliances - Others
Kneading paddle having problem kneading
Sounds like you might need a new belt. If it works ok with nothing in it but wont when the dough is in there
Feb 13, 2009 | Breadman TR875 Bread Maker
Bread paddle isn't "strong" enough to knead
Hi bex_ta,
If the paddle doesn't have the power to knead, you're probably losing torque at one or more of several points:
1) Where the paddle attaches to the shaft (is there evidence of slippage/wear in the paddle socket?),
2) Where the shaft goes through the pan (possible friction point - presumably this is what you oiled)
3) The belt might be slipping, either due to friction in the shaft, or because the belt is worn and loose.
You need to determine if the shaft is sticking, and if it's because it's bent (fairly unlikely) or if there's something fouling it. You'll need to isolate and fix that first. If you can rotate the shaft freely, then we look at (1) and (3) above - these are simple parts replacements, but the shaft would be more involved.
Belts are getting tough to find - if you can provide specs/measurements, I'm going to start contacting a small-run manufacturer to see about making some new belts, as I'm seeing multiple online requests for belt parts. If you happen to have a broken one, I'd like to get one as a sample to send to a manufacturer.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using,
Dec 08, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Cuisinart CBK-200 Bread Maker Logo
67 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
