Question about Kitchen Ranges
My manual clean oven range
I have a frigidaire smooth top manual clean range. I cannot seem to get the elements out in order to use an oven cleaner on it. Any suggestions. I think the range is about 5 years old. Help!
  • 1 more comment
  • Krogers Jan 18, 2008
    there is absolutely no self-clean on this poor thing. The elements that I am talking about are inside the oven the bottom and the top broiler heat elements. My fear was that I might screw up something on the electrical side of things.
    Thank you for your time. You have been very helpful. I might just have a clean oven! HA HA
  • Krogers Jan 19, 2008
    so don't use the easy off? What should I use?
    That is the reason for the question. It is a manual clean oven. There is absolutely no self cleaning involved. Will I still ruin the
    finish?
    President:
  • 1,314 Answers
You really don't need to remove them if your nervous just turn the power off at the breaker but they wont hut you as long as the oven isn't on
Posted on Jan 18, 2008
  • 3 more comments
  • robert samples Jan 18, 2008
    are you talking about the oven or top elements
    and are you sure its not self clean most glass tops are self clean look at the clock see if clean button is there
    dont spray no easy off in it will ruin the oven finish
  • robert samples Jan 19, 2008
    nothing if you have self clean cycle it will do it by its self just hit clean then start 3hrs should show then door will lock then will clean can wipe up any loose stuff with damp rag before starting but don't put nothing in it after cycle the door wont unlock till the oven senses its safe to open the door so it don't fry your face oven goes to about 800 degrees in self clean turns everything to dust
    nope
What oven heating element?
Hello Mary, I am happy to assist you!
I understand that you are unable to read the model number in the storage drawer of your Frigidaire range and that you are seeking the replacement part number for the element in your oven. Are you needing the bake or broil element? Do you remember if you register your range? In this regard, I would highly recommend reaching out to the manufacturer directly to verify if indeed your range was register in order to provide you the correct part number. Best regards - Z
May 05, 2014 | Frigidaire Kitchen Ranges
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not heat. all the burners on top work fine. what could be wrong?
Usual faults in this order are:
Faulty oven element - check element for holes, blow marks etc;
Burnt off wiring at the oven element terminals - check terminals;
If the oven indicator lights when the oven is turned on it should be the above. If it does not refer below;
Electronic clock set to auto. mode instead of manual mode.
Feb 12, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
On Frigidaire Self-Cleaning Range, bottom oven element does not work while top element does; bake relay problem?
Sounds like the bake element is out. Remove it and test it for continuity. If you need further assistance please feel free to contact me.
Jul 09, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire range model #FEFLFSA, is the top element
When you say Top Element, I assume you mean the TOP OVEN ELEMENT, correct? You have bake, and broil? Bake is usually on the bottom, and broil is the top. In order to have the oven operate correctly, the top and bottom elements may come on at start, in order to do as you just said, "Preheat the oven". This will insure an even distribution of the heat in the oven box and result in better cooking expierences. I would not be alarmed or concerned if the top element came on for a short period to pre-heat in preparation for cooking. This is normal. If the top element stayed on, and did not shut off on bake after the pre-heat period, then I would say you have a control board problem. However, if it comes on and then goes out, except when you are broiling, then I would say that this is normal for your stove, and the pre-heat mode of operations. Your owners manual should advise you of this very process in the guide section to how to use the oven. I hope this helps and that all your cakes, pies, souffle's and the like are......delicious. I'm sure they are. I hope this helps and eases your concerns. Kindest regards, Slats.
Sep 25, 2009 | Frigidaire Kitchen Ranges
Gas oven will not work.
the gas jet is proably clogged. Try cleaning with oven cleaner, if no luck use a pin on the the gas jet.
Aug 19, 2009 | Frigidaire FGF316 Gas Kitchen Range
Kitchen Ranges Logo
346 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
