Question about Samsung SCH-u740 Cellular Phone
I can't even get it to come on
Its been charging forever and the whole fun lights up but i can't get it to turn on once i take out the charger, what am i suppose to hit to turn it back on ?
    Brigadier General:
  • 7,752 Answers
You are having a software problem so take the phone to a mobile service center and let them reflash the firmware for you.
Posted on Jan 18, 2008
    President:
  • 1,017 Answers
Press and hold the END to turn your phone on.
Once your phone is On, it displays "Looking for Service" which indicates that your phone is searching for a signal. When your phone finds a signal, it automatically enters standby mode – the phone’s idle state. At this point, you are ready to begin making and receiving calls.
To turn your phone off: Press END for two or more seconds until you see the powering down animation on the display screen.
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Screen has began to flash on and off and wont charge
I had a similar situation with my pipo s1. After further investigation I found that the jack the charger cord plugs into went bad. My charge light wouldn't stay on unless you held the charger plug in a particular position. The jack is hardwired into one of the circuit boards and to replace the circuit board was half the cost of the whole tablet. I junked it and bought a kindle fire. Better quality and longer lasting battery.
Dec 12, 2013 | shop-fun PiPO S1 7 inch Tablet PC Android...
Battery charger reads battery full when dead
The battery is no longer good. You will need to buy a new battery. Don't over charge your batteries. They all vary. Expensive cordless tools will come with a charger that shuts off automatic to prevent over charging. I own cheap Skill drills that has served me well. These batteries lasted over 11years. It makes no sense. They should not have lasted more than 5 yrs., even 2yrs. I make sure I never over charged them, but they should not last that long. Freaky. Your battery is dead forever, sorry. I have others just like yours waiting to be recycled.
Sep 29, 2012 | GRACO INC TrueCoat 18V Lithium Ion Battery...
Whenever I charge the battery, the orange light on the charger won't light up/show. Then, when I put the battery in the camera, it will not turn on.
Rechargeable batteries don't last forever. This one may have simply stopped working.
However, it is worthwhile checking that the contacts on both battery and charger are clean. Dirt or corrosion can prevent the battery from charging.
There is also the possibility that the charger has failed. You can buy a new battery and try charging it. If it charges, then the charger is good and the old battery was the problem. If it doesn't, then you must get a replacement charger, and you will have a spare battery, which is no bad thing.
Oct 27, 2010 | Cameras
It does not turn on even if it was charged for 24 hrs
When it charges, does the red light come on on the charger? Some of the CST2000 chargers make bad connections, and they don't actually charge.
Make sure the red light is coming on when you're charging the battery. If the light is coming on and you still can't use the trimmer after charging, you'll need either a new battery or a whole new battery pack (the black handle of the trimmer).
Hope that helps!
Sep 04, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
My dynex portable dvd player 7 inch screen wont turn on!
Tries buy a new litium battery yet?Get a new adaptor charger?Tries it own website for adaptor charger or Amazon.com,Ebay.com many eclectronics parts excessorries.Tries ur local Radio Shack ask the clerk for help to buy litium battery or charger adaptors.
Oct 04, 2009 | Dynex DX-PD510
Nothing happens
The charger connection is sensitive on the Reflex Pro. It isn't uncommon to plug in the charger, see the light flashing, then when setting it down a slight movement of the cable stops the charging (light will stop flashing). Try connecting the charger again (if you haven't already) and let it charge for about an hour. While getting a good charge can be frustrating, it is worth it for the 4 minutes of fun to follow :-\
Aug 16, 2009 | Spinmaster Air Hogs RC Reflex Micro...
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Samsung SCH-u740 Cellular Phone Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
