Question about Reddy Heating & Cooling
I have a Reddy Heater Model R110. It has operated great until it ran out of fuel. I filled it up and now it will not ignite. It is pumping fuel as fuel is running out the front of it. I cannot find my owners manual so any help will be appreciated
  • 2,176 Answers
Remove the cover and check for spark at plug when plugged in if no spark check spark plug gor proper gap, or defective transformer electronic ignitor if you see spark check for proper pump pressure and restricted fuel flow due to seal leak, filter blocked and restriction in nozzle. I would check for defective photocell first for soot/dirt if dirty wipe with clean damp cloth remove photocell from heater and connect ohmeter on the 1000 ohl (rx1k) scale. Hold the lens up to a light source (60 wtt bulb, with the lens of the photocell pointed towards the source the resistance of the meter should be low by clocking off the light source by putting thumb over opening of cell the resistance on meter should be high, replace photo cell if a change in resistance is not observed during this test, let me know if you need more assistance
Posted on Dec 08, 2009
SOURCE:
I purchased a R110 Reddy heater for use in my
I have a manual for this,it is a pd f file,e mail me,and I will send it to you,roniecon@gmail.com
Jan 14, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater 60k kerosene suddenly smells
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Mar 09, 2009 | Reddy R60A Utility Heater
Unburned fuel coming from front nose cone when heating
in the back of the heater by the filter there should be a screw if yours is like mine screwing it in adds fuel backing it out gives you less make sure filtre is clean because if it isnt it will make it **** more fuel i took the cover off watched the ignitors and adjusted the fuel until it stoped making the jet sound and that is where i left it seems to be burning good there give it a try hope i helped
Jan 04, 2009 | Reddy Heater-30-55,000 BTU Variable
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy heater r110
Take reading on the air pump. Is sounds like the pressure is low, therefore not sucking fuel. It's a place to start, anyway.
How to check the pump pressure
Dec 05, 2008 | Reddy R60A Utility Heater
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Heating & Cooling Logo
353 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
T bone 1963
Superior Maintenance
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
