Question about GE Profile Harmony DPGT750EC Electric Dryer
Dryer stops tumbling
I have a kenmore 70 series model# 110.60722990 it starts up fine runs about 20 mins. and then stops tumbling the timer is still going but no tumbling. the lint trap is clean and great airflow coming out what could the problem be.
  • 770 Answers
First off you are posting a Kenmore question in the GE section look at the top.. Ikenfixit is right the thermal safety is a fuse if you will a one time (blow it and it has to be replaced) it is located on the gray blower duct behind the back wall you will have to remove the back panel (Unplug th eunit) and you will see it 2 wires It is white and looks like a fuse with ears on it You can jump it if you dont have a meter to test it and see if the dryer works
The main cause of failure on this part is a clogged vent going to the oputside so make sure it is cleaned out and blowing good outside
Posted on Jan 25, 2008
    Scholar:
  • 163 Answers
Thermal is opening for the motor or elements.. (May be 3-4 diff. snap-disks depending on model)..If the motor stops the heat will quit and Vise versa on most units..
Posted on Jan 18, 2008
I have a 70 series Kenmore dryer model # 66722694 it heats fine and runs fine but it cuts off for no apparent reason. after letting it sit or cool down for 15 to 20 minutes, it starts back up. i removed...
sounds like you have a bad heat sensor bypassing your fuse is an open invation to start a fire its there for a reason it also sounds like your timer is bad you might consider a new dryer dependimg on how old it is
Jan 19, 2011 | Dryers
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Have a kenmore series 70 dryer. Won't shut off
Yes it deffinetley sounds like you may have a timer issue, if your timer stops and the dryer is running, or if the timer keeps going around and around this will be the problem, however there are thermostats inside the dryer and if you have it set on a HEAT and not a TIMED setting the thermostats won't advance the timer because they havent been set.Hope this helps
Thanks.
Nov 22, 2009 | Kenmore Dryers
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 | Dryers
Kenmore dryer 70 series runs for 20 mins then turns off
It sounds like the timer to me!
With the old timers you could open it up and spray it with a can ot electrical cleaner (same as they sell for computers) and a lot of the time it would fix the problem!
This might also work on the circuit boards of a new washer!
Cost about $10.
Hope this was helpful!
Good Luck!
Jan 18, 2009 | Kenmore 73952 Gas Dryer
TUMBLE DRYER SUDDENLY STOPPED WORKING. ALL LIGHTS FULLY FUNCTIONAL BUT THE PROGRAM WON'T START WHEN START BUTTON PUSHED. RED LIGHT IS FLASHING ON START BUTTON. mODEL WTE6920
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Sep 15, 2008 | Dryers
Kenmore Dryer 70 series
Hi, the problem with the dryer not stopping is most likely the switch that controls when it starts. This switch is located behind the button you would push in to start the dryer, and if you can take off the rear panel and get to it, you can most likely adjust the internal contacts so that they don't continuously make contact. Or you could just replace the switch, which might be easier!
Jul 21, 2008 | Kenmore 64742 Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
151 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
