Inspect and clean your disc Take a close look at the
bottom side of your game, movie, or music disc (the side without a label or
image). Are there scratches? Excessive scratches or smudges can prevent your
console from reading the disc. Clean your disc Hold the disc by
the edges without touching the top or bottom surfaces. Using a soft,
clean, slightly damp cloth, lightly wipe from the center of the disc outward.
· Note Use ONLY water to
clean the disc.
Once the disc is clean, load the disc into your
console and see if the disc plays.
Or Click here to download repair guide
clean the disc.
you need to
purchase a lazer disc cleaner it looks and works just like a normal dvd disc
but it has brushes on it that when put through the player brushes the dust of
the laser lens this needs to be done on a regular bases to keep your lazer
working to its optimum level and hense fixing your problem.
by the edges without touching the top or bottom surfaces. Using a soft,
clean, slightly damp cloth, lightly wipe from the center of the disc outward. · Note Use
ONLY water to clean the disc. · Once
the disc is clean, load the disc into your console and see if the disc plays.
image). Are there scratches? Excessive scratches or smudges can prevent your console
from reading the disc. Clean your disc Hold the disc by the
edges without touching the top or bottom surfaces. Using a soft, clean,
· Note Use
· Once the disc is clean, load the disc into your console and see if the disc plays.
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your Game Disc. Please check our game play help for assistance.
the xbox has only been used since xmas should this be happening already
