Eliminate the battery as the issue first up.
Check if you can jump start the car from another vehicle with its engine running or at least have the starter motor kick over the engine. If it starts then you know your battery is the issue. Having lights does not mean the battery has enough cold cranking amps to turn over the starter motor.
2. If the starter cranks the engine over as normal with a jump start from another car but your engine does not start you have also eliminated the starter motor as the issue.
3. If it does not start and the starter motor will not crank the engine over either when you jump start from another vehicle, then there may well be a problem with the starter solenoid, the starter motor itself or with the wiring to the starter solenoid or to the starter motor. No power getting to the starter motor solenoid or to the starter motor and obviously the starter motor will not turn over.
4. So I need not write much more here, there is a very good guide to solving starting issues here which I suggest you might like to read.
No Start Problems
