Question about Dishwashers
Dishwasher my dishwasher works fine besides that the upper rack water dispenser only shoots out water from a stationary position it will not spin
  • Anonymous May 07, 2008
    Our dishwasher is a commercial grade type washer. We use it to wash metals and elements after sandblasting. My problem is that it won't spin, but it dispenses water. What can I do to rectify the problem?
Dishwasher does not spin but dispenses water
Posted on May 07, 2008
  • 2,039 Answers
Is the stationary full of dirt less pressure goes in it not gonna spin properly cheers
Posted on Jan 19, 2008
Tablet keeps coming out of the dispenser on my hotpoint fdl 570 dishwasher on all cycles and falls on to the floor, result is that the crockery isn't always clean on the top tray. Machine is still...
Hi Jeanette,
Maybe I misunderstood your question, but the tablet is supposed to come out of the dispenser and fall into the bottom of the dishwasher. It needs to fall into the hot water in the bottom of the washer to dissolve. The dispenser releases the tablet at different points in the cycle depending on which wash cycle is selected. On a shorter cycle it will be released soon after starting. On longer cycles, there is usually a rinse first, so the tablet will be released a little later. There would only be a problem if the tablet wasn't being released, or wasn't dissolving completely.
There are a number of reasons for poor cleaning on the top rack. The most common are the upper spray-arm not spinning, incorrect stacking or overloading. If the upper spray-arm isn't spinning, there may be caused by a blockage in the spray-arm or the water delivery system, but, as the dishwasher is new and it's not happening every time, it's possible that the dishwasher isn't levelled correctly. The spray-arms aren't motorised, they use water pressure to spin, but they wont spin if they aren't balanced, i.e. the dishwasher isn't level.
You can check whether the spray arm/s are spinning by pointing them front-to-back, or left-to-right (so you can remember the position) and allow the dishwasher to run for a few minutes. Then open the door and check the position of the spray arms. They should continue to rotate slowly for a short while after opening the door, but if they're in the same place and static, they're not spinning. I'd suggest repeating this a couple of times to eliminate the possibility of them having stopped in the exact same place you left them.
If the spray arms are spinning, test the dishwasher with only a small load in the top rack. If the top rack comes out clean with a small load, you may be overloading it or stacking it incorrectly some of the time. There should be a correct stacking guide in your user manual.
Hope this helps. If you need further assistance, check whether the arms are spinning then post back.
Regards,
BElectric
Jul 03, 2011 | Dishwashers
The unit is 6 years old. Dishes on the top rack do not get cleaned. Dishes on the bottom rack are fine.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 06, 2011 | KitchenAid Dishwashers
Both upper and lower water dispensing devices are not spinning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 01, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
We have a 2007 LG ldf6810ww dishwasher that suddenly is not getting dishes in the upper rack clean, nor is it fully removing the soap from its dispenser. I assume they're related and due to a lack of...
I once had gunk in the rotating sprayer itself that was blocking things...is the dispenser opening properly? I reckon a thorough cleanse with a dishwasher cleaning detergent (the one that takes a super wash to do it) and check the sprayers...no joke a chicken bone was in one of them!!
Aug 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Spray Arm Doesn't Move on my GSD5630d01ww!
When you say the dishwasher is running do you mean that the pump is operating?  If the pump is not pumping water the arm will not spin.  Is there a bottom arm and is it spinning?  If it spins then the pump is working. The upper arm will not spin if it is blocked by hitting a large dish or utensil.  There should be some sort of tube or tower (some are collapsible) in the center of the lower rack that shoots water into the bottom of the spin arm above.   Is it missing, blocked or clogged?
May 30, 2009 | Dishwashers
Kitchenaid KUDS02 Rinse Aid dispenser does not work
I don 't know how to fix the dispenser; however, there is a jet dry product that is sold in stores that is in solid form, you just clip it to the upper rack. I have seen it in Wal-Mart in the detergent aisle.
Sep 28, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Upper spray arm is not turning round even though water is coming through. We have checked the internal system for blockages and the machine is filling / draining as normal. When a full programme is run,...
I found the problem to be neither blockages of the upper arm or roof spray arm or the upper basket arm hitting the the back of the dishwasher. the problem was that the pump inlet where the food scraps are macerated was blocked with all manner of gunge including small chicken bones plastic and other detritus. Removal of the macerator housing under the upper filter housing using 2 different sizes of torx driver easily fixed the problem. Probably why the upper dish rack cleaning degraded overtime, Directly proportional to the amount of detritus blocking the intake screen behind the macerator.17a8801.jpgb9e8fa8.jpg789f2b8.jpgfb7a626.jpgator. See pics
Jul 13, 2008 | Dishwashers
Lower arm won't spin
the arm only rotates with water shooting out of the angled jets at the end of the arm and these are probably blocked ( i assume it is free to totate manually) take the arm out and run water into the centre hole and this will help push whatever is blocking it to a visible position - usually rice or sweetcorn. you say there are no obstructions in arm but when no water flowing, the blockage tends to slump back into the main body of the arm and out of sight
May 20, 2007 | Maytag 24 in. MDBS661A Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
