Question about JVC DR-MV1S DVD Recorder/VCR
JVC DR-MV1S DVD Recorder / VCR... Problem
Does anyone know how to reset to original settings
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 37 Answers
If you can actually reset the dvd/vcr recorder try the dvd menu...it should be under one of it's submenus
Posted on Jun 04, 2008
How do you Reset JVC DR-MV100 DVD Recorder/VCR Combo?
First press and hold the (Stop) button first and then press& hold the (Standby/On) Button until you see *RESET* flashing on & off on the display, hold both buttons in until the unit shuts down.
Nov 12, 2012 | JVC DR-MV1S DVD Recorder/VCR
Tip
Well, My JVC DR MV1s is reading and records my DVD-R but it stop reading and...
The most common mechanical problems that can prevent a dvd player from playing or reading the discs are the following:
1. The spindle motor not functioning properly (this is by far the most common, if the spindle motor is not spinning the discs then the optical lens can not read them). For the most part it is an cheap part to replace averaging around 25-35 dollars if you can replace it yourself. If you do not know how and have to take it to a repair shop expect to pay 50-75 dollars in labor depending on the area you live in. The best thing is to do some comparison shopping and call the different repair shops and get estimates. The key is to listen closely when you insert the disk into the player, you should be able to hear it spin up. If you hear nothing then that is most likely the problem.
2. The tray could be out of alignment. This is another easy and cheap fix if you have the proper tools. This could happen if you drop or pull/push to hard on the tray (which you should not really do anyway, but always use the open and close button). This is an example picture of the drive assembly with the tray open.
3. The small gears are plastic and often break, this will cause the players other parts to not move and function properly. They are difficult to reach, but inexpensive to replace. It is always recommended that you always order any part from the manufacturer of the device. A visual inspection is usually required to determine if the small teeth have been broken, which requires for the most part taking out the carriage assembly.
4. The small belt drives either break or come off. Again, this will cause the other mechanical parts not to function. They are difficult to put back on as well, so you may need an extra pair of hands if you have not done this before. On average you will usually have 2-3 of them inside your player.
5. The Optical reader has malfunctioned. This is the most expensive thing to replace, so you might consider purchasing another player depending on how much you want to spend and the original cost of the device, unless you can find a great deal on the part you need. You can check to see if the laser is firing with a visual inspection (DO NOT LOOK DIRECTLY INTO THE LASER) put in a disc with the case off and you should see the glow of the laser hitting the disc. You can also see the spindle/spindle motor.
Picture of the optical reading assembly dismantled:
6. The tray also has a drive motor which can fail and cause the cd tray not to open and it also has a track that it rides on (located in the drive assembly). Check these two components if you are having problems with your tray not opening and closing properly or stops working completely. Sometimes, the tray will open and then immediately close on it's own. This is usually caused by the track being dirty or some type of debris is lodged in the track. Cleaning the inside of the player with a can of compressed air will help remove dust and dirt. Blowing out the inside of the device once a month is a good preventative maintenance measure.
CAUTION: When working with any electrical device, you should always ensure safety first. Make sure that the device is turned off and unplugged from any power source. This does not completely prevent electrical shocks because Capacitors will hold an electrical charge for some time even if the device is turned off and unplugged.
The following are example pictures of what Capacitors look like:
on Sep 24, 2008 | Philips DVP5140 DVD Player
Der / VCR... View all results for: "dvd recorder vcr combo brisbane"View now! JVC DR-MV1S DVD Recorder / VCR Combo Approx how much in Australia
When the unit was new in USA, it retailed for around $550USD which at the current foreign exchange rate is about $542 (approximate). According to one forum, many people are advising that you steer clear of this 2004/05 model! It doesn't last. They have had numerous problems with this model.
I personally would not recommend that anyone bother with this particular model at all. Buy a better brand (it does not have to be new or terribly expensive). JVC products over the past few years have been less than reliable.
Mar 05, 2011 | JVC DR-MV1S DVD Recorder/VCR
Watch tv properly with JVC DVD off
Some philips tv's have a built in aerial amplifier, perhaps if you bought a digital aerial booster it will improve the picture quality.
Apr 05, 2010 | JVC DR-MV1S DVD Recorder/VCR
I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
I got mine on-line, though I've forgotten where. Do a search using "JVC DR-MV1 manual". If all else fails, I could send you a copy, The pdf size is 8196 kb.
Feb 03, 2009 | JVC DR-MV1S DVD Recorder/VCR
Code to unlock zone
Mine says it is a region 4 DVD player, but yours could be different. But referring to mine, i have played DVDs from overseas, e.g USA and KOREA with no problem. Its a fantastic piece of equipment, the JVC DR-MV1S. =)
Sep 09, 2008 | JVC DR-MV1S DVD Recorder/VCR
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
Cannot clear Dub
if it's the dub button/light key which glows green to dvd/to vcr....just press the button once or twice untill it turn off...
May 30, 2008 | JVC DR-MV1S DVD Recorder/VCR
Loading
ok, this same problem happened to many other jvc dr-xxxx s, i think the only answer to this would be to get it serviced or just chuck it out. the cause for the annoying "loading" blinking light is a blown out capacitator, inside the machine itself i recomend u to not try to fix it d.i.y.
Mar 13, 2008 | JVC DR-MV1S DVD Recorder/VCR
Jvc dr-mv1s video dvd recorder
switch the unit off at the plug and back on again.hey presto it opens again
Feb 24, 2008 | JVC DR-MV1S DVD Recorder/VCR
JVC DR-MV1S DVD Recorder/VCR Logo
303 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
