Question about Brother MFC-7220 All-In-One Laser Printer
New Ink Cartridge
Our brother MFC-7220 gave us an error message that said Toner Life End. We replaced the old toner and we are still recieving the same error message and can't print incoming faxes.
Apparantly, the machine is not recognizing the new ink cartridge.
What is your recommendation?
Thank you for your advice.
  • 1 more comment
  • pdhsi Apr 08, 2008
    we are using the new cartridge, but still having the same message after using 1 week. Pls help
  • Anonymous Aug 12, 2008
    PUT IN A NEW TONER AND STILL HAVE THE MESSAGE TONER LIFE END
  • Anonymous Mar 12, 2014
    Just bought new ink cartridges and now it says, "no toner/ink" and won't print
  • 3 Answers
Is the toner cartridge an original Brother or is it remanufactured? The toner cartridge for this model is the TN-350, which has a "flag gear" on the left (gear) side. It is a little plastic piece that sticks out on the new cartridges and, after putting the cartridge in for the first time, it rotates out of the way. This is how the printer knows that the cartridge is new. Some remanufacturers either don't put the flag gear in or they forget to turn it back to the original position when they build the cartridge. So that would be the first thing I would look at.
Posted on Jan 18, 2008
I posted this solution under the "brother laser cartridge refills" problem... but it applies here as well.
OK.. I agree that your problem is with the flag gear. However, there is a specific location in which it needs to be situated. The purpose of the flag gear is to trip a reset actuator on the left side of the printer. The correct position of the flag gear needs to be set so the reset actuator is depressed 3/4 of the way AND where the flag gear moves out of the way once this is done. If the flag gear is moved all the way forward, you run a risk of the gear mechanism inside not rotating it out of the way...which could leave you with a 'no cartridge installed' message. When the manufacturer of the toner cartridge made this unit, they decided to put a mark on the side to, evidently, let the assembly team know where to set the flag gear. Great for us :) On the outside plastic piece that you have to remove to get to the flag gear, you will see a diagonal line and a view window. When you rotate the flag gear, you will eventually see a portion of the white gear in that view window. Line up the white gear portion with the bottom of the diagonal line (typically two gear teeth), and you're done. Assemble and run!
Posted on Aug 01, 2008
Brother MFC 7820N, I am getting "Toner End Life"
I fail to see why you are covering up the toner sensor led's when you have a new cartridge fitted?
Also if you are using a recycled toner from a very well known uk shop that refills toners and ink then you may well have broken the drive gear that stirs the toner. i have seen this six times and their toners do this.
It could well be one of the pitfuls of recycled toners.
Jul 24, 2011 | Brother MFC-7820N All-In-One Laser Printer
I get toner life end but toner is brand new
remove the toner and wipe it with some cotton and insert it again....if not then may be you are not installing the toner properly or you are not removing the seal of the ink on the toner take it to a qualified technician so that he can check out for the error and assist you further .
Feb 10, 2011 | Brother MFC-7220 All-In-One Laser Printer
Hi, just replaced my toner on the MFC-7220 and a message Toner Life End is displayed and will not print. I have tried 2 brand new toner cartridges. Thanks, Linda
Hi there !
Try this solution if it works, the memory of your printer still programs that your toner is end.
Try to make hard reset of your printer by turning off your printer for 5-10 mins, unplug the power cord as well and remove the cartridge toner. Then return back the cartridge, plug the power cord and then restart your printer. Then try to print again.
If displaying still this message, just press stop button to remove the message.
Also, if there is wiper for cleaning the toner cartridge everytime your put new toner, please do it.
This is what we do in your bother MFC printer when this message appears. Just restart the printer and keep pressing stop button when the printer starts.
I hope it helps you. Regards.
Jan 31, 2011 | Brother MFC-7220 All-In-One Laser Printer
My Brother MFC-7220 shows the error message "Dust
Try cleaning the drum in the toner cartridge with a soft cloth. If this does not work then a replace toner cartridge is the other solution.
Nov 26, 2010 | Brother MFC-7220 All-In-One Laser Printer
I replaced already new toner cartridge for my brother fax machine mfc-7220 but still the on screen message is appearing on the display "TONER LIFE END". Pls help me to solve this problem. Tnx and God bless...
I replaced already new toner cartridge for my brother fax machine mfc-2820 but still the on screen message is appearing on the display "TONER LIFE END".
Apr 12, 2010 | Panasonic KX-FL541 Plain Paper Laser Fax
MFC 8460N giving Toner Life End message
I just solved my own problem. Try it for yours. I had been using several compatible toners for the MFC-8460N with no problems until today, as I posted earlier. On a hunch, I went to the local office supply store and purchased one original Brothers TN550 toner and put it into the printer and closed the cover. Everything clicked. Toner End Life message gone. I then took that Brother toner out and put the compatible one back in and still everything was fine. Am keeping the original Brother toner as a "kickstarter" if it happens again.
Mar 10, 2008 | Brother MFC-8460N Laser Printer
Replace ink toner message
Is it refill? if not then try leveling powder in cartridge by gently shaking, Take back as faulty, or reset new toner lever on left front of cartridge. Check toner is seated correctly in drum and drum seated correctly in machine.
Nov 08, 2007 | Brother MFC-7220 All-In-One Laser Printer
Mfc-7220 replaced starter cartridge, new Brother one gives error no cartridge
there is a new toner detect sensor left front upper inside of printer, when a new toner is put in reset lever on cart hits sensor then fall back to front of cart, remove gear asst and put lever in new position, 3/4 the way back. reinsert toner into drum and insert.
Nov 03, 2007 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC-7220 All-In-One Laser Printer Logo
733 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
