Question about Heaters
Reddy heater model PRO 110
Runs, I see spark not constant fuel flow changed in line filter, new air filter.
put in new fuel lines that are see through and not enough fuel going however fuel has leaked through injector nozzle and not burned found that in case when opened been cleaning and wondering what the %W$&# is the matter ?
  • 232 Answers
SOURCE: reddy heater pro 110
Does your heater use the older spark plug technology or the newer Hot Surface Ignitor (HSI) technology?
Without this critical information about all this technician can do is guess.
My best guess at this time would be either water in the fuel or a restricted fuel filter.
Posted on Nov 01, 2008
Need parts for readdy Heater Pro 110 New
Posted on Jan 08, 2009
  • 232 Answers
SOURCE: pro 110 manual
How to adjust the pump pressure
Posted on Feb 06, 2009
SOURCE: reddy heater pro 110 started up ok went to use it
cleaned electrodes , filter and sensor oiled fan motor
Posted on Dec 13, 2009
  • 540 Answers
SOURCE: Can I use #1 diesel in my Reddy Heater Pro 110?
YES! NO1 diesel is kerosene!
Posted on Dec 19, 2009
  • 188 Answers
SOURCE: motor went bad in a reddy heater pro 110 110,000 btu
The manufacturer is online at . If you go to that website you can find part distributors. I hope this helps you!
Posted on Feb 01, 2010
0 characters
1 Points
I have a clogged fuel line (filter?) I do I remove the bushing without damaging it?
(For 40/55/60/70/110/115/155/165 Models
1. Remove side cover screws using 5/16" nutdriver.
2. Remove side cover.
3. Pull upper fuel line off fuel filter neck (see
Figure 15 or 16).
4. Carefully pry bushing, fuel filter, and lower
fuel line (110/115/155/165 Models only) out
of fuel tank (see Figure 16).
5. Wash fuel filter with clean fuel and replace in tank.
6. Attach upper fuel line to fuel filter neck.
7. Replace side cover.
Jan 20, 2012 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I have reddy htr 35 was running great,just stopped reset breaker lit right up then went out Pulled cover off fan and spark fine reset it lights right up can see the fuel atomizing flame starts...
Check your fuel lines and most models have a fuel filter in line. A few things come to mind one how old is the fuel? Check the screen in the nozzle assembly by removing nozzle it sits directly behind the nozzle, these corrode and affect fuel flow. While you have this tore down clean the fire-eye with windex and terry cloth rag, it may not be seeing the flame. Check the air filter at the back of the heater as well. These are common problems with these heaters.
Dec 13, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
70,000 BTU Ready Heater
If...the air pump pressure is right, the ignitor glows, the fuel is hitting the ignitor, then the unit will have combustion......unless.....
  1. there is an air leak on the pressure line
  2. there is a vacuum leak on the fuel line
  3. there is a leak at the nozzle adapter
  4. there is a restriction either in the nozzle or the fuel filter
  5. the nozzle is worn and is spraying fuel rather than fogging fuel
Feb 09, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater runs then stops
it's the ignitor itself, if everythingelse is working or new then your just not getting enough spark. Also check your air lines as they do tend to get brittle and if your not getting enough air it won't light either.
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Master Reddy 30,000 btu heater put out nasty fumes.
Sounds like it's not getting enough air to fuel mix, check your air inlet line for breaks or just put a new one on for a couple bucks. any fuel line thats the right diameter will work, got mine from auto zone.
Jan 21, 2009 | Reddy R155D Utility Heater
Reddy heater pro 110
Jan 14, 2008 | Reddy Heater-30-55,000 BTU Variable
Heaters Logo
77 people viewed this question
Top Heaters Experts
Dan Webster
Dan Webster
Are you a Heater Expert? Answer questions, earn points and help others
