Question about Jl Audio 12W6v2 Car Subwoofer
Pioneer 1200 watts 12inch ts-w1207d4 dvc
Hi ,seems as if my speakers burnt a bit they would play but ,when u turn up the volume they trip out the amplifier.my question is how can i fix them?Thank you.
  • 70 Answers
If a friend has an amp too, see if it does the same thing to theirs and if it does, you'll probably have to replace the speakers, but if it doesn't do the same thing on theirs you've got a bad amp. but you never know, it could be the speakers and the amp but that isn't very likely
Posted on Jan 20, 2008
6ya staff
SOURCE:
I have 2 pioneer ts-w383 15" dvc subwoofers and cant get any sound out of them. a few days ago i got one to play but now neither one will play any sound.
I need help for my Opel Astra cd code.
DELCO ELECTRONICS CDR500
NO. 09136107
Type CDR500(E)
2F4
GM1500Y9242228
Thanks in advance !
Dec 02, 2013 | Pioneer TS-W383DVC Car Speaker
What amp to use for two pioneer ts-w307d4 car subwoofers
Just get 2pi amp pros at1200 watts. That way u have full control of the bass u need. Just remember to turn the amps down the subs are a little under rated. Done this myself and it is a great sous. There not a good pro sub but they will do the job in a mid size car
Jan 30, 2012 | Pioneer TS-W307D4 Car Subwoofer
What size box should i build fro two pioneer 12inch speakers 1200watts each
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches.
Mar 17, 2011 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Speaker works but smokes
need more info . what i know is this a subwoofer voice coil gets red hot in color its like the flame on a blowtorch when being played at high volume from the electrical current running through it . when the speaker is brand new you notice the smells like its on fire or burning up . this is normal it just breaking in the speaker . it goes aways few minutes later ...
give me more info into what is happening i can help you
Oct 14, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Is my 1200 pioneer amp a good match for my 1200 watt pioneer sub
this is too close, your speaker wattage is alway's higher than your amplifier's wattage alway's to be safe because the hard pounding will make the speaker work harder, and this will cause your speaker burn out easily, though you can adjust your amplifier anyway's
May 08, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
May 04, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
TS-W307D2
Design and Specifications
12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
Nov 23, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Spl box 12inch pioneer subs pls
this is from pioneer  http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/126763081TRD1217-A.pdf
Dec 16, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
Sub not playing to full potencial
you haave either connected it incorrectly.make sure the ohm of the speaker matches that of the amp ..connect the positive coil to the positive coil at the back of the sub and the same for negative .then run your cables to the amp .you should only have one positive cable and one negative cable .this connection will create a 2 ohm connection make sure the amp can handle that load .prefarably using a 2 channel bridgable amp or 1 channel monoblock
Feb 20, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
Jl Audio 12W6v2 Car Subwoofer Logo
102 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
matthew walsh
Level 1 Expert
Dalynn Turner
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
