Question about Canon PIXMA iP4200 InkJet Photo Printer
Bought compatible ink
The ink cartridge i bought requires the chip to be transferred over to the new cartridge ( will never buy these again they are shit ) my printer says i have 2 of the same kind inserted - which i obviously dont!
I want to chuck it in the bin!
is it possible that i the chip is damaged?
Re: Bought compatible ink
It's likely the chip. They can evidently get confused like the rest of us! Previous fixes were to replace the driver. No luck with me so I did what I was told by an idependant printer engineer and simply replace the offending colour cartridge. Hey Presto. Fortunately I was using Canons inks and they are going to replace it.
Posted on Jan 28, 2008
0 characters
3 Points
An unsupported black toner cartridge is installed
Some replacement cartridges require a new "chip" be installed to tell the printer that the cartridge is a match. I would check with New Egg and see if they forgot to send the chips, if required. I don't know of a manual bypass to the system.
Dave W.
Sep 14, 2012 | Xerox Phaser 6100/DN Laser Printer
Problem with fake ink replacement
you will have to get 4x new color chips. and replace it on the cartrdges
Sep 11, 2012 | HP LaserJet 2700n Printer
Change all Ink cartridges. Printer do not work now. It was working ok before I change ink cartridge.
Are these genuine Epson Cartridges? If not, Please try Genuine Cartridges for best results. If they ARE genuine ... take them back to the place you bought them and complain. If you already did that ... please ask your question again and mention these important facts.
Thanks for your question at
Jan 05, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Won't rege ink
how to reset ink cartridge for epson stylus cx6400 I have 2 sets of cartridges half full of ink and it will not print it just keeps saying out of magenta
May 16, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Ink cartridges not working in epson sx100 all in one printer
hi.make sure there is no tape or dirt on cartridge chip contacts.if still no joy trying iserting one cartridge at a time then installing.say insert black then will say others carts missing red blue yellow.keep going till they are installed.sometimes helps.make sure the carts have lastest chips installed version 5 or higher if compatable cart.should not be a problem if bought from t711 etc will fit but must be new carts with new chip otherwise may not accept.i belive the sx100 has something like t811 or something.this may be the new chip.otherwise may just be a faulty chip on the can get refillable carts or ciss system on ebay you put in your own ink.they are brillant.cart chips reset when low ink.hope this may help.
Jan 27, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printer cartridge for Kodak 5100 in India
Hello akpunj,
So far, there are no other ink cartridges that might be compatible with the Kodak printers, and even if you refilled the ink cartridge, it wouldn't help because of the smart chip they have.
Honestly, I think your best shot is to find somewhere else where kodak is selling this printers and where it will be cheaper for you to have them sent in.
Nov 21, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Epsom stylus CX4700 won't print - new ink cartridges installed
They cut costs on Epson compatible cartridges by using low quality ink and chips or not resetting the chips at all. Sounds like you got cartridges that the chips were not reset on so your printer thinks all the cartridges are empty. I own a Cartridge World ink refilling store and I would never recommend purchasing compatible Epson cartridges from anyone. I would buy refills of Epson brand cartridges and make sure the seller reset the chips.
Oct 18, 2008 | Epson Premium Compatible** Inkjet...
Epson DX8400 cartridge
It is most likely a faulty chip, return the cartridge to the supplier for a replacement. In my experience as many as 5% of compatible cartriges are faulty
Jul 02, 2008 | Epson CX8400 All-In-One InkJet Printer
Canon MP520 cartridge swap and ink refill
Canon MP520 multifunctional device - deactivation of the ink level counter
1. You can do it only when the printer counter releases the warning message - "the ink cartridge is nearly empty" = yellow warning mark
2. You have to do this procedure four times - for every cartridge one times
3. At the screen you will see three warning messages
- for the first one press "OK"
- for the second and third one press "Yes"
4. The fourth message tells you that you can do the ink level counter deactivation by pressing the "Stop/Reset" button (7) for more than 5 seconds. Do it.
Later you can see another type of warning message at the screen:
In this case you can not follow the previous procedure - there will not be any other warning messages.
Just follow the message on the screen and press the "OK" button (5) and you can print.
Unfortunately - I do not know for how long time it works.
You have to manualy check the ink level and refill (change) the cartridge before it is completely empty! You might brake your warranty!
When you insert the new original ink cartridge, the counter will work properly again.
Jun 08, 2008 | Canon MP520 All-In-One InkJet Photo...
Compatable tanks for my pixma iP4200
Guys...try to save a few bucks on crappy cartridges...
The chips are not read by lasers. That was a load. There are contacts in the carriage assembly for thses chips.
First, if you put a chip that says empty onto a new cartridge, what do you get? A new cartridge that still says empty. The chip has to be reset, if it can be. Some internet sites sell "Kits" for resetting the chips.
If the reset doesn't work, and just buggers up the chip, you'll get results much like what you are describing.
Also, if the chip is damaged in some way during transfer or resetting, you'll also get mixed results much like what you are describing.
You get what you pay for. If you want to use crap cartridges or crap ink, buy a crap generic machine. If you're buying a decent machine like a Canon, spend the extra couple of bucks for the OEM ink, it's worth it.
Oct 19, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
51 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
