If you hover the mouse pointer over the little speaker in the bottom right corner and right click you can turn it on from there. Or open the control panel and look in the Audio section you can turn the sound on from there. With out seeing your keyboard I can only suggest you look for a key with a little speaker with a line through it. you may also need to press the "Fn" key or the "Alt" key at the same time.
Try to press Fn + Num Lock or Fn + Scrl lock to check if they keyboard will respond. If it doesnt. try to turn off the computer, remove the cables and battery, press/hold the power button for 8 secs. Reinsert cables and battery then turn on the pc. Press again Fn + Num Lock or Fn + Scrl lock. If the keyboard still did not respond, go to the device manager . Click Start > right click My Computer > Properties > Hardware > Device Manager . Then click the (+) on Keyboards, right click the device and uninstall it. Then, go back to the device manager and right click Keyboard then click Scan for hardware changes. Then press FN + Num Lock or Fn + Scrl lock. If symptom persists, call HP to replace your keyboard.
Sounds much like the shift key (on the right of the keyboard obviously) has got stuck. Or possibly your cat has managed to turn on the marvel that is StickyKeys.
ITs for turning on the CAPITAL letters on the keyboard. All you have to do is Hit on CAPS LOCK key on your keyboard and you are done.
Nothing wrong with the PC/Notebook.
