Connecting TV-DVD recorder-Sky plus
How should i connect a panasonic tv to my sky plus box and sony dvd recorder (to record contents of sky box to dvd) ?
Scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
Posted on Jun 14, 2008
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Oct 26, 2013 | Panasonic DMR-E65 DVD Recorder
I watch tv via Digital DVD recorder but am unable to see sky tv. Do I need an analogue recorder
You need an analogue receiver to view the co-ax output from your sky box but you should be able to connect via scart
Feb 08, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
Connecting DVD recorder to TV and SKY box
A simple solution - aerial input socket error - wrong socket!!
There are too many choices on the DVD record/play machine. When the plug came out - it was pushed back into the wrong socket.
Nov 30, 2009 | Sony RDR-GX300 DVD Recorder
I have recently bought a sky plus hd box and want to connect an external dvd recorder to it(Sony). Followed instructions but it will not pick up a signal from the hd box by the way I live on the costa del...
if you connect the dvd to the tv using scart socket 2 (av2) it should send a signal to the dvd, depending on the make/model of tv, you also may have to set the av2 output in the menu.
Alternativly, connect the sky to the dvd input and the dvd output to the tv, this should also work.May have to watch the tv with the dvd on set to av.
Nov 20, 2009 | Televison & Video
How do i connect dvd recorder to tv only receiving sky channels through skybox
If you have two scart sockets on your tv,then connect a scart from av1 on the dvd into the tv,then connect a scart from the sky box into av2 on the dvd,your recording channel on the dvd will be av2.
If you only have on socket on the tv,then connect a scart from av1 on the dvd into the sky box,your recording channel will be av1,connected like this you may have to turn off the sky to watch dvd`s.
Oct 30, 2009 | Televison & Video
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Televison & Video Logo
268 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
