Question about Sony Handycam DCR-TRV510 Digital Camcorder
TRAP DOOR WONT CLOSE - Sony Handycam DCR-TRV510 Digital Camcorder
  • Garino May 03, 2008
    I just powerd on my DCR-TRV510 and it gives me the error message
    C:32:10.  Any ideas.  I also smacked the side but no luck.Thanks  Gary
I had the same problem with my camcorder. I removed the tape transport control from the top of the unit (be careful not remove the attached ribbon cable). It appeared that the ribbon cable attachment was bent a little. I straightend it out and reset it in the camera and re-attached the transport. Once this was complete I returned power to the unit and pushed the door closed and the trap door closed in place.
I was also having a problem with the unit not wanting to play the tape. I was getting Error Code C:31:XX or C:32:XX. I read in another forum that several people with same error message tapped or hit the tape side of the unit (similar to the way a television would be hit to try and get a signal). I had previously called Sony but the repair would be about half the cost of the camera ($500) and a repair shop quoted me $400. With nothing to loose I smacked the side of the camera a few times and belive it or not "IT WORKDED!!!" Something mechanical must have been out of line or loose. Unfortunately I purchased a New JVC Hard Disk camcorder prior to trying this, so now I have two perfectly good units.
Posted on Apr 14, 2008
How does it work?
Put bait on the pan inside then on the side of the trap there is a trigger mechanism where one arm rest on another arm that holds the doors open. When the animal messes with the bait the 1st arm will move allowing the 2nd arm to fall closing the end doors.
Apr 09, 2014 | One Stop Gardens 32-1/2 L x 10 W x 13-1/4...
How do you set this trap
There will be a trigger mechanism on the side of the trap. When you raise the doors the trigger mechanism has two points where one will rest on the other holding the end doors open. I would recommend putting the bait on the trigger pan before you set the trap. When ever the animal touches the bait it causes the one arm to move in turn allowing the second arm to fall closing the doors trapping the animal.
Dec 04, 2013 | One Stop Gardens 32-1/2 L x 10 W x 13-1/4...
Lg dryer wont turn off
If the dryer continues to run when you open the door you will need to replace the door switch. Here is the part to order.
Nov 03, 2012 | Dryers
Trap door for ice does not close all the way
This happens from time to time. There is a kit to replace the door flap assembly. It isn't to awfully hard to replace. Post a model number and I can tell you what part number you need to order :)
May 31, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Side door wont open from inside or outside ??
try taking off the inner trim card off the sliding door, and putting your hand inside to see if you can feel the little moving plate that the locks operate, its connected to a slim steel rod and if that off it wont open. You may need to butcher the door card if the door traps it when shut and it wont come off with it closed.
Jan 17, 2010 | Toyota Previa Cars & Trucks
Bosch dishwasher, SHE43M 30" built-in, door won't latch closed, yet can still start cycle.
check latch on dishwasher side of the unit to make sure it has `nt got loose they make them so you can remove them when the unit is discarded so children can`t get trapped in side
Nov 06, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The trap door on my icemaker appears to have come off its hinge and won't close all the way -condensation in freezer
The trap door mounts to a plastic spring loaded arm that usually cracks and or brakes,if you can replace this arm it should fix the condensation issue.Also the trap door might need to be replaced because it has a foam gasket that the foam wares out over time and won't make a good seal.
Sep 21, 2009 | Refrigerators
My washer wont start it just gives an E inthe display
Try pressing the pause start button holding it for a few seconds, also check door is closed with no washing trapped
Jul 18, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Hp officejet 6210 all-in-one
open that door, clear the jam , mostly paper trapped
close door and acknowledge with pressing button next to okay.
Should disappeasr.
If not still jammed.
If not, reset the printer.
Apr 11, 2009 | HP OfficeJet 6210 All-In-One InkJet...
No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Nov 07, 2006 | Sub-Zero 690 Side by Side Refrigerator
Sony Handycam DCR-TRV510 Digital Camcorder Logo
140 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
