Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
KitchenAid K5SS Switch lever replacement
Please tell me how to open the motor housing to replace switch lever on my KitchenAid K5SS. Any cautions?
Remove the philips screw at the back of the head, and remove the name band. This exposes the 4 screws underneath. Unplug mixer. Remove the 4 screws and lift the top off of the head. Switch and motor are right there. Gently remove the 4 wire plugs, after marking them. Unscrew the 2 screws holding the switch down and lift out the switch.
Posted on Feb 07, 2008
My mixer wont stay turned off it springs back to number 1 speed so i have to turn off via plug socket
Shelly, usually this can be repaired without needing ANY parts! Its pretty simple but you do have to tear apart the mixer. Here is a link to the service manual: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
99% of the time you are dealing with a loose screw. So take the mixer apart, once you have done that you will find the speed control lever with knob has a screw that holds it in place and in contact with the spring. That screw can work loose and if not all the way tightened will allow your mixer to pop back into speed one. Simply tighten the screw and see if the mixer will operate correctly.
If the speed lever is working through all 10 speeds correctly re-assemble the mixer. If it does not correct the problem you will want to buy the speed control lever kit.
This will include a new speed control lever with knob, the spring, link and a gearbox gasket.
KitchenAid Mixer Speed Control Lever Kit 4176230
The part number you will be looking for is 4176230, it is only about $7 plus shipping of $3.25.
-Colleen @ Mending Shed
May 14, 2015 | KitchenAid K5SS Heavy Duty Commercial...
I have a kitchenaid K5SS. The beater keeps hitting the bowl even after adjustment screws was adjusted. What else can I do to fix problem
Check the four large screws at the back of the motor housing. They screw up thru the pedestal into the gear/motor housing. If they are loose that can allow the motor to tilt forwards. Check also the ones under the pedestal base, I have never seen those ones loose though and they would not cause your problem.
Mar 24, 2014 | KitchenAid K5SS Heavy Duty Commercial...
Bowl lift arm replacement
Purchase the plastic lift lever arm first. Remove motor from pedestal with the 4x large Philips head screws underneath the back of the motor housing. Note which way around the lever is on the shaft (take a photo is a safe way) Remove split pin with some pliers, don't wreck it as you will need to re-use it. Punch out the roll pin that locates the plastic lever to the shaft. Fit the new plastic arm CORRECTLY. Punch the roll pin back where it belongs, making sure it is evenly engaged as too far in or out will make it foul. Put the rod back thru the lever and split pin it again. Check operation before you put the motor back on.
Mar 16, 2014 | KitchenAid K5SS Heavy Duty Commercial...
My kitchen aid K5SS won't run
first check the motor brush and replace them with a new pair. if you never do that check youtube and see a video how to do it.
Dec 05, 2012 | KitchenAid K5SS Heavy Duty Commercial...
Model K5SS -- The speed control lever will not stay in the slowest position - STIR - but will pop over to the next position - 2. Can I adjust anything to fix this problem?
Open up the Motor Housing and inspect the Switch Lever with Stud.
The Lower Gearcase has many depressions which allow the stud to
snap into it when the Speed Selection lever is moved. If the Stud
is worn out then there isn't much you can do but replacing it.
3184193 is the Switch Lever And Stud part number for your model.
Jul 03, 2011 | KitchenAid K5SS Heavy Duty Commercial...
No power to the K5SS any help would be great looks like all connections are fine
Check to make sure everything is attached correctly,
Could need cleaning in motor housing which is very common, if you know how to get inside...
estimated cost $29-$39.99
Nov 22, 2009 | KitchenAid K5SS Heavy Duty Commercial...
I have disassembled my K5SS Kitchen Aid mixe with all gears removed in order to solve its electrical problem. When I plug in the motor and move the speed lever, there is no movement or sound of the motor...
Unless it sits at the back of the motor behind the vent cover. I couldn't find one anywhere on ours either. Check the motor brushes for broken or badly worn carbons, or collapsed springs. It could be a broken wire at the plug end or something wrong with the speed switch. Some strategic voltmeter sleuthing is required. Try turning the motor shaft while the power is on. It may have a dead commutator segment.
Aug 25, 2009 | KitchenAid K5SS Heavy Duty Commercial...
KichenAid K5SS Speed lever does not stay in ''off'' position. When the lever is placed in the off position it moves to speed 1 immediately.
Hi Burt. Go to mendingshed.com, look up kitchenaid mixer parts. Near the top of the page, locate the free kitchenaid service manual. Download this valuable manual, it will help you to diagnose and repair your mixer. Mending Shed also sells KA parts. If you order parts directly from kitchenaid be prepared to wait for at least a month for the parts to arrive.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 14, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Oil leaked from housing
my ultra power ksm90gr 300 watt mixer leaked oil when in the upright position overnight. whats that all about?
Nov 10, 2008 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
561 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
