Problem with Malber WD1000 Front Load All-in-One Washer / Dryer
Dryer won't dry
I put my clothes in the unit and it is very loud and wabbls it is portable and it is even on the floor.
I tried all the the solutions in the back of the manual and it still doesn't dry. I also tried to dry it for 6 hours and still did not dry. Why is this, is the heating element bad or is this normal?
Posted by avatar on Jan 18, 2008
    • By avatarmikey67 Jan 20, 2008
    • dryer does not dry
Solutions (1)
Best Solution
The dryer heating element on this machine typically burns out after about 2 years. I have replaced one on my machine. To determine whether the cause is the heating element, unplug the machine and remove the top cover. You will see an aluminum duct across the top. Near the back of the duct, two wires connect to the heating element. Get ready to connect two wires of a voltmeter to those two wires. Plug machine in and turn on dryer mode. If there is voltage of about 110 volts across the two wires (be careful) , but the top of the aluminum duct does not feel warm after acouple of minutes, the it is most likely the heating element. I got on shipped to me for $29, but it is a little tricky to install. If you are handy, you can do it.
Add Your Solution
See all Malber WD1000 Front Load All-in-One Washer / Dryer Problems
