Question about iLO 3200 32 in. LCD Television
Direct TV Remote - No Codes Operate TV
I have a Toshiba model 23A40 TV Recently had Direct TV DVR installed. Tried each code, plus the procedure to check all codes - nothing works.
Purchased a universal remote - still no luck. Any suggestions??
Thanks
  • 3 Answers
I couldn't find any info on that particular model, but if it has a built in DVD or VHS player you cannot program the Direct TV Remote to it. You will have to use both remotes. The Direct TV one to change the channels and the TV remote for the TV functions.
Posted on Jan 24, 2008
I need the codes for the norcent tv to program it with the one for all remote.
manual code method
1. Press and hold the SETUP button until
the red indicator stays on, then release
the SETUP button.
2. Press and release the desired mode
button (TV, DVR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4-digit code from the code
tables (on separate
sheet). Note: after a
valid code entry, the
red indicator turns
off. For an invalid
code, the red indicator
?ashes.
4. With your device on,
press ON/OFF. If the
device turns off, no
further programming
is required. Note: If
some buttons do not operate your
equipment, try one of the other codes
for your brand.
If your device does not respond after you have
tried all the codes for your brand, or if your brand is
not listed, try searching for your code by following
these steps.
1. Manually turn on the device (TV, DVR, etc.) to
be controlled.
2. Press and hold the SETUP button until
the SETUP button.
3. Press and quickly release the desired
mode button (TV, DVR, etc.). The red
indicator blinks off once.
4. Press the CHAN+ button repeatedly
(up to 300 times) until the device to be
controlled changes channel.
The red indicator blinks off
with each button press. If
you accidentally overshoot
the code required, press the
CHAN- button to backtrack through the library
until the device changes channel. Pressing
CHAN+ changes direction to forward again.
5. Press and release ENTER to install the code.
Most users will store DVR codes under the DVR
button, Cable codes under CABLE, etc. If
(for example) you want to store a DVR code
under CABLE, ?rst follow the procedure
for Direct Code Entry (page 7) and press
enter
there are a few one for all remotes,if i knew what one i could help you more,i will list links to each manual for each one,
cant find any codes,buy a new remote for your tv here,,
Norcent RC00169P L19W698 L22H998 L22W898 L24H898 LT 1931 LT1931 LT 2231K...
Apr 23, 2015 | Televison & Video
Remote Code for Comcast DVR
See http://www.comcast.com/corporate/customers/customer_support/remotes.html
You will most likely have to use a VCR code and program it to the AUX button.
Feb 26, 2010 | Panasonic PV-C2541 25 in. TV/VCR Combo
I need trhe codes for direct tv for my jumbo remote its a dvr box
Here are the Innovage Jumbo Remote codes for Direct TV satellite boxes:
200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217.
If none of these control all of your DVR functions, try adding these DVR codes from other manufacturers:
146, 147, 148, 184
These codes work for Tivo, Replay TV and dvr models made by Panasonic, Philips, RCA, and Sony.
Hope that helps.
Oct 03, 2009 | Innovage Jumbo Remote Control
Programmin my remote
Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 You could try the one below..
I know the new HD boxes and DVR HD Boxes have the new remotes and they included Olevia on it and it works with the new models of Olevia's
Jul 15, 2009 | Olevia LT32HVM 32 in. LCD Television
DIRECTV HD DVR REMOTE CODES WILL NOT OPERATE DVR
If you turn off power saver on your tv it should correct the problem...
Mar 02, 2009 | Bose Cinemate Digital Home Theater System...
Universal Remote Codes
Try, 0045, 0043, 0845 or 0154, 0156, 0060
Feb 03, 2009 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Direct TV HD Receiver/Recorder codes
Check the Innovage manual for the automatic code search. If it works, you still may not have full control of your HR20. Try to program your Directv remote to operate your components
Jul 07, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Remote Control Codes don't work with my LCD TV
There is no code!!! -- Solution...You have to buy a universal remote with learning capabilities. I’ve ordered one that will not only learn off other remotes but can handle 10 components also. I got it from 10x it’s called the iconRemote control…if you call the company they will give you a discount (but you have to call them and ask) AWESOME!
Jan 02, 2008 | Sylvania LC320SL8 Television
Jumbo Universal Remote
I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
Dec 26, 2007 | Universal Remote Control NspireGear MP3...
Need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Oct 01, 2007 | One For All URC-3021 Remote Control
iLO 3200 32 in. LCD Television Logo
256 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Saylor
Level 1 Expert
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
